Previous Thread This topic has been viewed 21014 times and has 2 replies Next Thread
wrosun
Nepal
cool Television Feat.Wolverine
Hello Friends!
Here is a lcd televison that
reflects Lights and is transparent so it displays a picture of wolverine
. Hence it is Named "Televison Feat. Wolverine".
It must be place inside a room that has ceiling i.e create room and check on display ceiling. Then place a light source or just check on ceiling light to give your room a light source it works outside a room also but you need to make the sunlight rays hit on the screen of yout tv to make the image visible. To make lighting efect from the TV you can also use advanced rendering lights and check on lamp lights whilw rendering. Keep the quality on best all the timr for better results. check on compute glass transparency just to be sure.
You can download it from here
tv:only ceiling light turned on
Tv:ceiling + three more lights turned on
use more lights to make the screen more bright!!
[Note from moderator: fixed image links]
[Edit 1 times, last edit by Puybaret at Nov 28, 2010, 11:21:25 AM]
[Nov 28, 2010, 11:07:27 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
wrosun
Nepal
Re: Television Feat.Wolverine
Thanks Puybaret
for fixing the image links.....
What do you think about the TV?
[Nov 28, 2010, 3:26:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
wrosun
Nepal
Guys i found out one thing that causes the tv to not be transparent.....if you have checked in sunlight while rendering then the tv wont look like its turned on...even if its placed inside a room also...
[Nov 29, 2010, 5:27:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
