Re: Cut out
Mic,
I still haven't looked at your files (the download is very slow), but I've seen the pictures. Some time ago I wrote a manual that explains how to make a dormer. You may want to study it, because I think it solves your problem.
Re: Cut out
i used hatch and invisible box in door windows selection when importing but they just dont create a whole on wall?!?!
You probably forgot to check the Door or window check box during the 3rd importing step. Only doors or windows can make holes in walls.
i did read the how to make a dormer how to make a dormer. i cant see TOOLS section on my sweet home 3D !!!!
You probably forgot to install some plugins as mentioned in the introduction. I feel you want to go to fast. I you take your time to read manuals entirely (they are not so long), you'll get many answers by yourself.
Re: Cut out
thank you, i have understood the settings about it, i clicked doors and windows box in 3rd import level, my mistake was that i thought i have to import them to doors and windows category, i misunderstood it i guess...
so u say tools are added when i make the plugin, ok i will read more carefully,and then add that tools plug-in when i m ready to .. well that software is just awesome and just what i needed, i m tryna search and get every set ups to create what i imagine, thanks...
Re: Cut out
"Doors and windows" category is just a name, but I understand it's a little miselading.
Re: Cut out
Sorry to reopen this!
I have imported the invisible box and checked the door/window box, but if I then try to drop a door onto the box it won't snap to it and create a cutout.
