Re: GPU for better rednering
Sorry to break your hopes, but the GPU is only used to compute the 3D view and the images at the two lowest quality settings in the photo/video creation dialogs. Images rendered at the two best quality settings are computed only by the CPU. The more cores the CPU have, the faster the rendering will be computed.
would be genius...
Miserably I'm not a genius. Using the CPU and the GPU power are two completely different tasks, even more with from a program written in Java. So as said before, next time prefer to update the number of cores of your processor. Using an Intel i7 instead of an i5 really makes the rendering process go twice faster.
Thanks for keeping me aware about progress in graphics card, but don't hope any miracle in the coming versions, because I don't think Global Illumination can be supported easily from Java 3D.
Nevertheless, I recently learnt about shaders and shadow mapping technics and hope to try it sooner or later in Sweet Home 3D since Java 3D supports shaders. Meanwhile I might improve light effects in the 3D view as the following images show but I'm not sure this option really worth it.
In current version, lights placed in the home have no effect in the 3D view:
In this image computed with subpartSizeUnderLight property set to 20 cm, lights added to the home replace default lights in the room where they are placed:
Compared to the following Global Illumination rendering, there's still no shadow, no mirror effect, and lights are limited to their room and level:
When you see how poor the 2nd rendering is compared to Global Illumination, I wonder if offering an option to activate lights to end users is such a good idea.
Hi, thanks for the answer. I just realised who you are when I saw your signature. I bought your book "Les Cahiers du programmeur Swing" years ago when I started my studies. I knew I was familiar with the word "eTeks" but it didn't ring a bell. Anyway I'm impressed
Regarding GPGPU, I hope you'll find a way to speed up the rendering. Because a 2 megapixels image with light and shadows computes for 15 to 20 minutes on my Intel Core i7 2600k.
By the way, I noticed a slight problem in the rendering. When I run multiple rendering in a row, after a while the software starts using half the CPU cores, slowing down everything. I solve the problem by restarting the software.
Nevertheless, the "ligth" option in 3D view could help me mesuring light sources intensity. I usualy run a full rendering before noticing light was to bright or poorly placed. This option could save me a lot of time.
Do you have a release date for the coming version ?
Happy to meet a reader of the book that introduced Sweet Home 3D.
Note sure I'll propose this option. A developer reported me some crashes when he tried it.
Probably around the end of February, once the last features will be programmed and localization finished.
Thailand
excuse me, sir. How about to optimise rendering by the graphic workstation (nVIDIA Quadro or AMD Fire Pro ) by the way is the 3d sweet home for android version release yet?
