Duplicating object will not release the cursor
Mac OS 10.6.8 I have been creating a building drawing columns and girts using the Miscellaneous box object; which has been working fine.
when duplicating an object however using click select option drag, it often gets histrionic, and will not release; the dragged duplicate will not drop as a new object and the cursor remains a green circular + , only closing the active window allows me to escape ( escape key, enter, return - none have any effect. Sometimes multiple objects get created as one tries to click drop the replicate, Sometime they appear to be created by the cursor is still locked...
Is this a bug or should I be using a different approach?
Re: Duplicating object will not release the cursor
It looks like a bug. Does it happen all the time you duplicate? Do you use laptop or a trackpad?
it feels like a bug
not all the time but 70% of the time ( maybe)
One can end up with 6 or 7 copies of the object and the cursor will not release
on an iMAc 27 8MB RAM using a mighty mouse
Another bug seems to be adding .dae files; 2 separate examples have ground it to a halt, Activity Monitor shows sweetHome 3 D running 120+% of CPU wrt the problematic .dae Only quitting and deleting the furniture item from the left panel restores functionality
Only my first day with SH3D, quite impressed, but clearly some issues
Please give links to the DAE pages that caused some problems if possible. Maybe you chose too big files. Generally trees with too many details just slow down the software.
node105, I have the same kind of computer, and couldn't reproduce your issue after many attempts with the current beta version 3.4. Sorry, you'll have to give more details to help me reproduce this bug.
testing this am choose model (zip) takes 2 minutes initial blue spinning ball, (then Apple multi coloured spinning pizza wheel Continue button remains greyed, Activity Monitor show SW > 100%, cursor can release back to pointer and Continue remains greyed - Force quit SW required
I stress that this is not just one source file, I have had this happen with 3 different files. Just did 10 or 12 imports, and most were ok.
THe one file (tree) caused a hang on 3 different import attempts, but imported ok on another 2 attempts
My feeling is it is in the initial import sequence I did think that it may have been something to do with .zip files, but sometimes it works and others not, and has failed on import of the unpacked .dae as well.
On some occasions the ( If the following information isn't correct, update it ) Name text in the wizard is red, then continue is not available, using the go back button, then continue usually makes it go black, but the Continue button remains greyed unless the name is changed
At one point in repetition testing I felt it was not changing the default ( bathroom) import destination) to something els ( miscellaneous) that was the cause of the subsequent freeze, but testing this am, hangs have happened regardless
THe file ( a tree) that initially caused , and occasionally continues to cause problems ( in re -import testing - having deleted, and quit…) is a tree
Yes I did consider that it may be a file size issue expecting a tree render to be more complicated, but it has also happened on a different file ( but now do not know which one)
ganyedes_s Aceraceae which I think I found in Google Sketchup as a Collada zip
Attached log extract my help:
20/11/11 7:20:43 AM kernel Limiting closed port RST response from 297 to 250 packets per second 20/11/11 7:25:38 AM [0x0-0x8d08d].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7653] Exception in thread "AWT-EventQueue-0" 20/11/11 7:25:38 AM [0x0-0x8d08d].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7653] java.lang.OutOfMemoryError: Java heap space 20/11/11 7:25:42 AM [0x0-0x8d08d].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7653] at javax.media.j3d.Shape3DRetained.doSetLive(Shape3DRetained.java:996) 20/11/11 7:25:45 AM [0x0-0x8d08d].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7653] at javax.media.j3d.Shape3DRetained.setLive(Shape3DRetained.java:975) 20/11/11 7:25:51 AM [0x0-0x8d08d].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7653] at javax.media.j3d.GroupRetained.childDoSetLive(GroupRetained.java:2196) 20/11/11 7:26:10 AM [0x0-0x8d08d].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7653] Exception occurred during event dispatching: 20/11/11 7:26:10 AM [0x0-0x8d08d].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7653] Exception in thread "Poller SunPKCS11-Darwin" 20/11/11 7:26:12 AM com.apple.launchd.peruser.501[126] ([0x0-0x8d08d].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7653]) Exited: Killed 20/11/11 7:26:51 AM kernel Limiting closed port RST response from 288 to 250 packets per second 20/11/11 7:28:21 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] Exception in thread "J3D-MasterControl-1" java.lang.OutOfMemoryError: Java heap space 20/11/11 7:28:21 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at java.lang.reflect.Array.newInstance(Array.java:52) 20/11/11 7:28:23 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.IndexedUnorderSet.add(IndexedUnorderSet.java:404) 20/11/11 7:28:23 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.RenderMolecule.removeRenderAtom(RenderMolecule.java:1686) 20/11/11 7:28:23 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.RenderBin.removeARenderAtom(RenderBin.java:5907) 20/11/11 7:28:25 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.RenderBin.removeAllRenderAtoms(RenderBin.java:5934) 20/11/11 7:28:25 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.RenderBin.cleanup(RenderBin.java:6913) 20/11/11 7:28:25 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.View.reset(View.java:3390) 20/11/11 7:28:32 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.MasterControl.handlePendingRequest(MasterControl.java:3320) 20/11/11 7:28:39 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.MasterControl.doWork(MasterControl.java:3121) 20/11/11 7:28:39 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.MasterControlThread.run(MasterControlThread.java:67) 20/11/11 7:28:41 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] Exception in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: Java heap space 20/11/11 7:28:43 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at java.util.ArrayList.<init>(ArrayList.java:112) 20/11/11 7:28:43 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.Shape3DRetained.<init>(Shape3DRetained.java:92) 20/11/11 7:28:45 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.Shape3DRetained.doSetLive(Shape3DRetained.java:996) 20/11/11 7:28:45 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.Shape3DRetained.setLive(Shape3DRetained.java:975) 20/11/11 7:28:46 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.childDoSetLive(GroupRetained.java:2196) 20/11/11 7:28:46 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.doSetLive(GroupRetained.java:2249) 20/11/11 7:28:48 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.setLive(GroupRetained.java:2188) 20/11/11 7:28:48 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.childDoSetLive(GroupRetained.java:2196) 20/11/11 7:28:50 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.doSetLive(GroupRetained.java:2249) 20/11/11 7:28:52 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.TransformGroupRetained.setLive(TransformGroupRetained.java:567) 20/11/11 7:28:54 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.childDoSetLive(GroupRetained.java:2196) 20/11/11 7:28:54 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.doSetLive(GroupRetained.java:2249) 20/11/11 7:28:56 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.TransformGroupRetained.setLive(TransformGroupRetained.java:567) 20/11/11 7:28:57 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.SharedGroupRetained.childDoSetLive(SharedGroupRetained.java:887) 20/11/11 7:29:01 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.doSetLive(GroupRetained.java:2249) 20/11/11 7:29:01 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.setLive(GroupRetained.java:2188) 20/11/11 7:29:03 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.SharedGroupRetained.setLive(SharedGroupRetained.java:310) 20/11/11 7:29:04 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.LinkRetained.setLive(LinkRetained.java:178) 20/11/11 7:29:06 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.childDoSetLive(GroupRetained.java:2196) 20/11/11 7:29:08 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.doSetLive(GroupRetained.java:2249) 20/11/11 7:29:10 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.TransformGroupRetained.setLive(TransformGroupRetained.java:567) 20/11/11 7:29:10 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.childDoSetLive(GroupRetained.java:2196) 20/11/11 7:29:12 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.doSetLive(GroupRetained.java:2249) 20/11/11 7:29:13 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.TransformGroupRetained.setLive(TransformGroupRetained.java:567) 20/11/11 7:29:15 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.childDoSetLive(GroupRetained.java:2196) 20/11/11 7:29:17 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.doSetLive(GroupRetained.java:2249) 20/11/11 7:29:19 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.TransformGroupRetained.setLive(TransformGroupRetained.java:567) 20/11/11 7:29:19 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.childDoSetLive(GroupRetained.java:2196) 20/11/11 7:29:21 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.doSetLive(GroupRetained.java:2249) 20/11/11 7:29:22 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.BranchGroupRetained.setLive(BranchGroupRetained.java:187) 20/11/11 7:29:24 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.childDoSetLive(GroupRetained.java:2196) 20/11/11 7:29:26 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.doSetLive(GroupRetained.java:2249) 20/11/11 7:29:50 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] Exception in thread "Poller SunPKCS11-Darwin" 20/11/11 7:29:52 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] java.lang.OutOfMemoryError: Java heap space 20/11/11 7:29:55 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at sun.security.pkcs11.wrapper.PKCS11.C_GetSlotInfo(Native Method) 20/11/11 7:29:57 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at sun.security.pkcs11.SunPKCS11.initToken(SunPKCS11.java:767) 20/11/11 7:29:59 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at sun.security.pkcs11.SunPKCS11.access$100(SunPKCS11.java:42) 20/11/11 7:29:59 AM Sweet Home 3D[7763] java.lang.OutOfMemoryError: Java heap space 20/11/11 7:29:59 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at sun.security.pkcs11.SunPKCS11$TokenPoller.run(SunPKCS11.java:700) 20/11/11 7:30:01 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at java.lang.Thread.run(Thread.java:680) 20/11/11 7:30:01 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] Exception in thread "AWT-EventQueue-0" 20/11/11 7:30:03 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] java.lang.OutOfMemoryError: Java heap space 20/11/11 7:30:20 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] Exception in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: Java heap space 20/11/11 7:30:53 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] Exception in thread "AWT-EventQueue-0" 20/11/11 7:30:55 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] java.lang.OutOfMemoryError: Java heap space 20/11/11 7:31:01 AM com.apple.launchd.peruser.501[126] ([0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763]) Exited: Killed 20/11/11 7:39:00 AM kernel Limiting closed port RST response from 254 to 250 packets per second 20/11/11 7:40:39 AM kernel Limiting closed port RST response from 268 to 250 packets per second 20/11/11 7:44:52 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] Exception in thread "Timer-0" 20/11/11 7:44:54 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] java.lang.OutOfMemoryError: Java heap space 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.lang.StringCoding$StringEncoder.encode(StringCoding.java:232) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.lang.StringCoding.encode(StringCoding.java:272) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.lang.String.getBytes(String.java:946) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.io.UnixFileSystem.canonicalize0(Native Method) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.io.UnixFileSystem.canonicalize(UnixFileSystem.java:157) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.io.File.getCanonicalPath(File.java:559) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at sun.security.provider.PolicyFile.canonPath(PolicyFile.java:1849) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.io.FilePermission$1.run(FilePermission.java:186) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.io.FilePermission$1.run(FilePermission.java:183) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.security.AccessController.doPrivileged(Native Method) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.io.FilePermission.init(FilePermission.java:183) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.io.FilePermission.<init>(FilePermission.java:249) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.lang.SecurityManager.checkRead(SecurityManager.java:871) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.io.File.lastModified(File.java:824) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.eteks.sweethome3d.tools.OperatingSystem$2.run(Unknown Source) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.util.TimerThread.mainLoop(Timer.java:512) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.util.TimerThread.run(Timer.java:462) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] Exception in thread "pool-11-thread-1" java.lang.OutOfMemoryError: Java heap space 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.util.regex.Pattern.compile(Pattern.java:1451) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.util.regex.Pattern.<init>(Pattern.java:1133) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.util.regex.Pattern.compile(Pattern.java:823) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.lang.String.split(String.java:2292) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.lang.String.split(String.java:2334) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.eteks.sweethome3d.j3d.DAELoader$DAEHandler.endElement(Unknown Source) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(AbstractSAXParser.java:601) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(XMLDocumentFra gmentScannerImpl.java:1782) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2939) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:648)
20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragm entScannerImpl.java:511) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:808) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:737) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:119) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.xml.parsers.SAXParser.parse(SAXParser.java:395) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.xml.parsers.SAXParser.parse(SAXParser.java:198) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.eteks.sweethome3d.j3d.DAELoader.parseXMLStream(Unknown Source) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.eteks.sweethome3d.j3d.DAELoader.load(Unknown Source) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.eteks.sweethome3d.j3d.DAELoader.load(Unknown Source) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.eteks.sweethome3d.j3d.ModelManager.loadModel(Unknown Source) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.eteks.sweethome3d.swing.ImportedFurnitureWizardStepsPanel.readModel(Unknown Source) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.eteks.sweethome3d.swing.ImportedFurnitureWizardStepsPanel.access$1400(Unknown Source) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.eteks.sweethome3d.swing.ImportedFurnitureWizardStepsPanel$37.run(Unknown Source) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.lang.Thread.run(Thread.java:680) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] Exception in thread "Poller SunPKCS11-Darwin" 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] java.lang.OutOfMemoryError: Java heap space 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at sun.security.pkcs11.wrapper.PKCS11.C_GetSlotInfo(Native Method) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at sun.security.pkcs11.SunPKCS11.initToken(SunPKCS11.java:767) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at sun.security.pkcs11.SunPKCS11.access$100(SunPKCS11.java:42) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at sun.security.pkcs11.SunPKCS11$TokenPoller.run(SunPKCS11.java:700) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.lang.Thread.run(Thread.java:680) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] Exception in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: Java heap space 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at apple.awt.ContainerModel.getSurfaceBounds(ContainerModel.java:70) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at apple.awt.CPeerSurfaceData.setBounds(CPeerSurfaceData.java:106) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at apple.awt.ComponentModel.replaceSurfaceData(ComponentModel.java:531) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at apple.awt.ComponentModel.getSurfaceData(ComponentModel.java:470) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at apple.awt.ComponentModel.getGraphics(ComponentModel.java:465) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2840) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JDialog.getGraphics(JDialog.java:1090) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:784) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:714) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:694) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.RepaintManager.access$700(RepaintManager.java:41) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1672) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] Exception in thread "pool-11-thread-2" 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] java.lang.OutOfMemoryError: Java heap space 20/11/11 7:47:59 AM com.apple.launchd.peruser.501[126] ([0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940]) Exited with exit code: 143
Long import = big models = lot of memory, and from OutOfMemoryError appearing in the log, it's actually a memory problem. Even if you might find that weird, Java programs can't consume as much memory as they want. If you want to increase the max amount of memory the program can use in the downloadable version, please read the FAQ, but if I were you, I would simply forget the idea of using this model.
I am well used to flaky Java
Hum, not sure you speak to the right person if you want to criticize Java! ;) I don't say Java is perfect, but without it, no portability and no Sweet Home 3D under Mac OS X!
