Re: Bay Window
This is more a room extension than a bay window, in my view. So, I would treat it as one by drawing walls and inserting windows. That way you can have a floor and ceiling as well. Note that you can stack two windows on top of each other, if the window configuration should closely match your picture.
bay window.sh3d
Re: Bay Window
I'm not sure if it could work as I need to rise in floor level and lower the ceiling height in the window area in order to match the actual status. Let me try and update you later. Thx so much Hans.
Re: Bay Window
Fanyam,
There's a solution for everything. 1 - Use SH3D version 3.3 with the CopyAsNewFurniture plug-in installed. 2 - Design your "bay window" 3 - Use boxes for floor and ceiling 4 - Use CopyAsNewFurniture and then Export to OBJ format to export your window as a model. 5 - Use Import furniture to use your model.
