about roofs
I have a problem with roofs. After i make one from a wall, i export/import as obj, I always get a surface (visible from only one direction in the 3dviewer but always showing up in pictures) where the ground used to be. It always happens to me but I see pictures on the forum, without that surface... ...How do you get rid of it?
Re: about roofs
CC,
Use SH3D version 3.3 and install the plug-in CopyAsNewFurniture (see tutorial PDF ). The plug-in copies your elements in a slightly different way, without the floor part. The 3.4 beta version cannot handle the plug-in.
