Total posts in this thread: 9
Previous Thread This topic has been viewed 14521 times and has 8 replies Next Thread
pr1970
Pan in aerial 3d view
hi all
Been using Sweet Home 3d for a while (great program btw) but I always find the aerial view is difficult to move into the correct position, I cant find out how to pan confused , just rotate and zoom. Anyone help?
Thanks
[Feb 4, 2012, 12:45:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Pan in aerial 3d view
Panning the 3D view isn't possible.
Rotating can be done by moving the mouse with the left button held down. Alternatively you can use the green arrows in the "windrose" in the top-left corner of the 3D window.
Zooming can be achieved by rolling the mouse wheel.
[Feb 4, 2012, 2:24:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Please read also the FAQ Is it possible to manually set the rotation center of the 3D view in Aerial view mode?
[Feb 4, 2012, 4:37:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pr1970
ok thanks. Real shame you cant move around the 3d view as its quite difficult to see small rooms without it. The virtual visit helps a little but its a bit awkward to use. Nevermind.
Thanks
[Feb 4, 2012, 10:54:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Yehonal
Thanks
There is an easy workaround using virtual visit. Just set the height of virtual viewer 10x of the normal. And you can see the house just like aereal view but you can also pan moving the viewer.
[May 2, 2014, 1:35:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
TorQueMoD
Canada
That's a great work around but how does one set the height of the virtual viewer?
[Nov 19, 2019, 8:04:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SeppoV12
Finland
Two ways to set the height of the virtual viewer:
1. double click virtual visitor icon and in opening window set 'Eyes elevation' value other than default (170 cm)
2. Use menu for that: 3D view - Modify virtual visitor...
When you handle very large objects, virtual visitor is often hard to find. In this case method 2 is always possible.
Tip: if you want to see if pillow is on top of bed (height 45 cm) or floating above it, go close and set Eyes elevation bit more than bed height (=>46 cm).
Then (if necessary) adjust pillow elevation for realistic value, for example 44.5 cm.
[Nov 24, 2019, 10:18:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SeppoV12
Finland
Third and maybe the best choise: keyboard shortcut Ctrl+Alt+M
(PC/Windows)
[Nov 25, 2019, 10:23:39 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
johncclee
The way I pan is by adding walls to spaces outside of the floorplan I am drawing. This helps by shifting the 3D render to accomodate the new detail.
Not perfect but quick and easy. smile
[May 10, 2021, 11:16:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
