Features
Total posts in this thread: 6
Previous Thread This topic has been viewed 6575 times and has 5 replies Next Thread
rohitverma
transparent vertical and horizontal glass square
Can someone create a model for a transparent see through square which is transparent through any object including walls , doors also.
e.g: Five pane window in (doors and windows category) without the frames..just glass part of it....if we have a wall of thickness 5 and place five pane window on it with depth 8 ...we are able to see objects behind wall through the window
The idea is that we should be able to see objects behind it transparently.
There should be 2 models created
1) horizontal (0 height)
2) vertical (0 depth)
somebody please reply
thanks in advance
[Feb 15, 2012 11:57:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Re: transparent vertical and horizontal glass square
Would a transparent box help?
[Feb 15, 2012 12:59:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
rohitverma
ya that will more than do..thanks...
[Feb 17, 2012 3:25:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
adlerhn
Europe
A transparent box will create holes in walls; good.
However, for some reason, it does not create holes in the ceiling (at least not box_invisible.zip).
[Jul 7, 2016 3:23:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message    http://www.nightearth.com [Link] Report threatening or abusive post: please login first  Go to top
It will if you import it again, marking it as "Stairs" during import.
[Jul 7, 2016 6:30:59 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
adlerhn
Europe
Great trick!
[Jul 7, 2016 9:30:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message    http://www.nightearth.com [Link] Report threatening or abusive post: please login first  Go to top
