Features
Total posts in this thread: 6
Previous Thread This topic has been viewed 3063 times and has 5 replies Next Thread
Carina2011
problem with import and texture problem
i have the problem when i import a texture( so they must look)
and so it looks when i import this
I can select the file from the importer but what the problem is that the model textures are not loaded anyway ...
Now my question ... How do I get the point that the textures to be loaded when importing into SweetHome3D? I can select the file from the importer but what the problem is that the model textures are not loaded anyway .
[Mar 29, 2012, 3:38:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Re: problem with import and texture problem
Wat kind of file is it ? Dae, obj, 3ds, zip?
[Mar 29, 2012, 4:12:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Carina2011
Both in obj and 3ds
[Mar 29, 2012, 4:17:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
If both the 3DS and the OBJ file show the model without its textures, than most probably the models aren't included in the download. There are a few sites that offer free models without textures.
If you downloaded an OBJ file, check if there is also a MTL file for the textures. If it's a ZIP file, check if within the ZIP file there's an OBJ and an MTL file.
[Mar 29, 2012, 4:39:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Carina2011
i have make the model. i have check al both mtl etc. but it dont work ;(
[Mar 29, 2012, 5:08:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You should check how you exported your model from the modeler you use. First the faces are inverted, something you can fix with the check box at the second step of the import furniture wizard. Then, maybe you didn't generate texture coordinates or files have incorrect names (avoid spaces).
[Mar 29, 2012, 7:15:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2020 eTeks - All rights reserved
