SH 3D do not start
Hi! My problem is after the installation (I've alredy tried to use the online and jsp method, but it doesn't seems work!). When I launch the application i can see only the starting window, then the program crashes (without signal) and i find this report on my desktop: # # A fatal error has been detected by the Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6954ac8e, pid=3516, tid=1452 # # JRE version: 7.0_04-b20 # Java VM: Java HotSpot(TM) Client VM (23.0-b21 mixed mode, sharing windows-x86 ) # Problematic frame: # C [atioglxx.dll+0x51ac8e] # # Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
I've an Ati Radeon 9550 series... Help me, what I can do???
Re: SH 3D do not start
It's probably due to a problem in the video driver of your computer. See the FAQ for suggestions about how to fix it.
