Re: Copy as new furniture Plugin Source Code
The function of the CopyAsNewFurniture plugin has been integrated in SH3D. You don't need the plugin anymore.
It works as follows" - select the model that you want to export - click 3D View --> Export to OBJ format - give a name and click Save - select Export selection You can then import the model again.
On the Documentation page you can download a tutorial for plugins. It also gives the locations where you can download them.
The CopyAsNewFurniture plugin still provides something that Export to OBJ format doesn't support: it's also able to copy (then paste) lights included in the selection.
