Germany
Re: Upload file, to work on it online.
Welcome pimol,
what exactly do you mean with this? AFAIU this should work already. Simply mount your webspace via WEBDAV-protocol and save your project there. Then you are able to work on it online.
It would be wonderful, but... I can't find any help/how to. I can't be able to understand in which way I can open my file (it already is in a webdav drive) using the online version: it show me only the home I create online!
Germany
Emmanuel,
can you clearify that this is only valid for the ONLINE editor? As far as i understood this is only a problem if you use the online version. Otherwise the file on a server (e.g. via WEBdav) behaves just like any other file beeing accessed by SH3D localy.
macfrog, the limitation is only on the online version provided on sweethome3d.com. If Webdav works like a classic file system, there's no problem.
