Re:
Graphics problems...
I tried to close almost every process in windows and found this to be responsible: In my case the audio driver NahimicSvc32.exe has caused the graphical issue with the 32bit app. Closing NahimicSvc64.exe helped also for the 64bit app version.
Re: Graphics problems...
Bonjour, j ai un problème similaire avec un pc tout neuf zenbook15 Asus, avec Ryzen7 et AMD RADEON. Sous windows11 64 bits. J ai installé la version sh3d 7.2 et la visualisation 3d plante complement, des traits partout qui ne ressemblent à rien. Surtout pour le mobilier. Help🙏
Anne, mettez à jour le driver de votre carte graphique, c'est un problème déjà corrigé par AMD.
Italia
Good evening, I'm using SH3D since years. Never had problems with previous revisions. Since I need the SW today, I bought last revision from Microsoft Store and it doesn't work properly. I have the same problem described by other users. My graphics drivers are already updated (NVIDIA RTX). O.S. is Windows 11: Edizione Windows 11 Pro Versione 23H2 Data installazione: 21/09/2022 Build sistema operativo 22631.3447 Esperienza Windows Feature Experience Pack 1000.22688.1000.0 Hardware is: Nome dispositivo Mostro Processore 11th Gen Intel(R) Core(TM) i7-11700K @ 3.60GHz 3.60 GHz RAM installata 32,0 GB (31,8 GB utilizzabile) Tipo sistema Sistema operativo a 64 bit, processore basato su x64
Please let me know if you need further info. PS Disabling "NahimicSvc64.exe" had no effect.
Italy
Can you describe the problem? If you have the Pan 3D view plugin installed, maybe you should update it too to the last version; try to remove it first.
