Re: Graphics problems...
Thanks for the quick reply, but unfortunately the same problem continues after uninstalling the 64 bit version and replacing it with the 32 bit version ... after a minute or so, moving the mouse begins to create endless duplicate views of parts of the window.
Any other thoughts?
I had used SH3D in the past without any issues. I have a design of my home that I would really like to be able to access.
Additional System Info:
Sweet Home 3D ® Version 6.1.2 Java version 1.8.0_202 - 32bit - 0.1 / 0.6 GB Java 3D version 1.5.2
OS Name Microsoft Windows 10 Home Version 10.0.17134 Build 17134 System Manufacturer Micro-Star International Co., Ltd. System Model GS65 Stealth Thin 8RF System Type x64-based PC Processor Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz, 2201 Mhz, 6 Core(s), 12 Logical Processor(s) Installed Physical Memory (RAM) 16.0 GB Total Physical Memory 15.8 GB Available Physical Memory 8.34 GB Total Virtual Memory 32.8 GB Available Virtual Memory 21.9 GB Page File Space 17.0 GB
Install the program in 32 bit again, then copy the SweetHome3D.l4j.ini attached to this post in the installation folder of Sweet Home 3D (probably C:\Program Files (x86)\Sweet Home 3D) and restart the program.
---------------------------------------- SweetHome3D.l4j.ini
(119 bytes)
(Download count: 1986)
(Properties file for DirectX 32 bit)
Thanks, Puybaret! That seems to be a good work-around.
After a 10 min test, everything has worked fine on my primary monitor. Oddly, though, as soon as I move it to my external monitor, the program now crashes.
Another side note that may be helpful from a development standpoint: the problem seems to be some conflict with the nvida card (driver up-to-date directly from nvidia).
With the standard installation (prior to adding your ini file) I found last night that if I disabled my nvidia card and only ran with the onboard graphics, everything ran well.
I also tried the opposite, but with that the problems continued (nvidia card only ... onboard graphics disabled).
Find java.exe and/or javaw.exe likely found in C:\Program Files\Sweet Home 3D\jre8\bin\javaw.exe Right click on it and select -> Properties Go to Compatibility tab Check Override high DPI scaling behavior. Choose System for Scaling performed by: Click OK
i hope it may help you
