Re: Graphics problems...
Quickly said, the payed version offers the same features + all the furniture and textures libraries available on sweethome3d.com. So sorry, don't hope that the payed version will offer some bug fixes that wouldn't be available in the GNU GPL version (or very temporarily). You could try older versions like the version 4.6 which used an older Java version. If it works, then replace the *.jar files found in lib subfolder of the installation folder with the ones of the latest version (therefore make a copy them before uninstalling the version of Sweet Home 3D you have).
So seeing as Puybaret or any one else has not come up with a vaild fix yet I am going to dual boot windows I already have win10_x64 clean install. I have issues with free and bought versions with every thing updated as much as possible.
So win7 will be installed wednesday and updated and will see what this program does then.
So updated version 6.21 released friday has been running on windows 10 x64 with current drivers for 2 hours without issues. Exact same system where 6.12 had the graphic corruption issue
Nathan Mai seems to have found a solution to this issue. It would be nice if more users could report how it works for them.
Sweden
It would be absolutely amazing if the solution would be to disable any running "overlay software" as per Puybaret's link. I'm struggling to see any application thought that fit this description on my system. Could other users with this issue confirm if this has worked for them? BTW. With v6.3 I have far less problems with this issue than in previous versions, but it still occurs every time I use the software.
Sweden
I can't see to be able to edit my previous post. I just want to share an update. In desperation I, more or less, closed all open applications. It actually seems to work… I'll do more detailed tests in the next days.
