hi, i'm new to SH3d. Can not render one of my project. No problems with other files. Can not export to obj file to render with blender.
java console shows following error
Can't load texture: CLOTH_02.JPG Make sure it is located in the same server an d directory with the model file. the loader's base path is: jar:file:C:\Users\mi gui\Application Data\eTeks\Sweet Home 3D\work\3500-dda97bcc-c9e6-4442-8023-21e2b e1f305e\open8802407051458218221.sweethome3d!/185/ Exception in thread "AWT-EventQueue-0 " java.lang.ArrayIndexOutOfBoundsException: -1 at java.util.ArrayList.get(Unknown Source) at com.eteks.sweethome3d.model.Home.clone(Unknown Source) at com.eteks.sweethome3d.swing.PhotoPanel.startPhotoCreation(Unknown Sou rce) at com.eteks.sweethome3d.swing.PhotoPanel.access$000(Unknown Source) at com.eteks.sweethome3d.swing.PhotoPanel$1.actionPerformed(Unknown Sour ce) at javax.swing.AbstractButton.fireActionPerformed(Unknown Source) at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.setPressed(Unknown Source) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Sour ce) at java.awt.Component.processMouseEvent(Unknown Source) at javax.swing.JComponent.processMouseEvent(Unknown Source) at java.awt.Component.processEvent(Unknown Source) at java.awt.Container.processEvent(Unknown Source) at java.awt.Component.dispatchEventImpl(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Window.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source) Exception in thread "autoSaveTimer" java.lang.RuntimeException: java.lang.reflec t.InvocationTargetException at com.eteks.sweethome3d.io.AutoRecoveryManager.cloneAndSaveHomes(Unknow n Source) at com.eteks.sweethome3d.io.AutoRecoveryManager.access$500(Unknown Sourc e) at com.eteks.sweethome3d.io.AutoRecoveryManager$8.run(Unknown Source) at java.util.TimerThread.mainLoop(Unknown Source) at java.util.TimerThread.run(Unknown Source) Caused by: java.lang.reflect.InvocationTargetException at java.awt.EventQueue.invokeAndWait(Unknown Source) ... 5 more Caused by: java.lang.ArrayIndexOutOfBoundsException: -1 at java.util.ArrayList.get(Unknown Source) at com.eteks.sweethome3d.model.Home.clone(Unknown Source) at com.eteks.sweethome3d.io.AutoRecoveryManager$9.run(Unknown Source) at java.awt.event.InvocationEvent.dispatch(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source)
Re: Can not render or export to obj file
I found the issue in your file. Very strangely, you had two pieces of furniture named "Bombilla Incandescente" and "aplique-pared" which didn't belong to any level. Once they were removed, it worked. Do you use some plug-ins with your version of Sweet Home 3D?
Emanuel thank you very much like you said, there is a grouped object not belonging to any level. I could reproduce this behavior. This happens when I grouped two objects (incandescent light source + lamp object). Hope this helps sorry for my english!
Thanks for the test case. I fixed the bug and the correction will be available in the next version.
