Features
Previous Thread This topic has been viewed 68270 times and has 15 replies Next Thread
Textures Library Editor released
Here's the Textures Library Editor, a tool that will help Sweet Home 3D users create and manage SH3T files.
The program is available as a 900 kB JAR executable file (see the end of this post for updated links) and requires you installed Java on your machine (or reuse the Java version embedded with Sweet Home 3D installer).
The easiest way to launch it is to double-click on the file. If this method fails, choose open or launch with Java in its contextual menu, or open a Terminal window and run the command:
java -jar TexturesLibraryEditor-1.5.jar
Supported systems are Windows, Mac OS X 10.4 to 10.13, Linux and probably any system that supports Java 1.5.
If you look for an icon for it, take the following one based on a texture of mine:
Very similar to the Furniture Library Editor, this tool will let you import more than a texture image at a time either with a classic file dialog displayed by the Import textures tool, or by dropping the files in the window of the tool if your system supports this feature.
Once they are imported, you may modify each texture, or by group after selecting them. As the screen capture shows, the modification dialog displays the attributes of a texture (for those interested it's even possible to edit the ID attribute after a small modification in the program).
This tool is also a translation tool that will help translators to localize more easily SH3T files: the name and the category entered in the modification dialog depends on the language chosen in the tool bar, and when you select a new language in this drop down list, all the categories belonging to 4 default categories are automatically translated into the selected language, if the language belongs to the ones supported by Sweet Home 3D at this time.
Caution, there's no undo/redo feature. As always create backups to ensure you won't loose your work. This editor should be stable, but I release it as a beta version to fix easily bugs that may appear. Note also that during its development, I discovered a bug in Sweet Home 3D 3.6 and previous versions, that will save all the images of a SH3T library in a SH3D file as soon as you use only one of them. sad
So, upgrade to a newer version, or if you can't, choose to create small SH3T files rather than a big one if you don't want your SH3D files to grow too fast.
For interested programmers, source code is committed in the TexturesLibraryEditor SVN module separated from SweetHome3D one.
Project contains a README.TXT file with compilation directions.
I hope this tool will be useful and that you'll like it (and even more, once the bug fix in Seeet Home 3D will be released). biggrin
Updated links to Textures Library Editor JAR executable:
Textures Library Editor 1.5 was released on 10/05/2015
Textures Library Editor 1.4 was released on 06/12/2014
Textures Library Editor 1.3 was released on 10/30/2013
Textures Library Editor 1.2 was released on 06/03/2013
Textures Library Editor 1.1 was released on 03/21/2013
Textures Library Editor 1.0 was released on 10/25/2012
[Edit 10 times, last edit by Puybaret at May 25, 2018 1:54:20 PM]
[Sep 11, 2012 12:07:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
speed777777
south africa
Re: Textures Library Editor released
hi emmanuel used new textures library ed now that 3.7 is out, please tell me how to delete a new texture once placed in textures library, as no option to modify or delete is available to use, once imported. using jar ex version. cheers shaun
[Oct 26, 2012 10:17:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
You can't delete a texture image coming from a SH3T file from Sweet Home 3D. Simply edit the SH3T file with the Textures Library Editor and delete it from there, then reimport the SH3T file in Sweet Home 3D (don't need to restart it).
[Oct 26, 2012 10:40:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
stcruz
Good days, working with the publisher(editor) of textures I meet the following problem:
On having imported a texture with transparency "texture.png" when the file to guard as texture sh3t the textures with transparency they do not guard. Some solution?
Thank you very much.
[Apr 29, 2014 3:31:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Brakat
Egypt
Sore im Arbic man i don't understand it's my first work on Sweethome i just need add more Textures to program thank u :)
[Aug 12, 2014 9:56:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    https://www.facebook.com/Ali.Elsayed.brakat [Link] Report threatening or abusive post: please login first  Go to top
Brakat, you're not at the good place to get more textures.
Go there to download more textures, and if it's not enough, visit web sites cited in textures import page.
[Aug 12, 2014 10:17:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
Brakat
Egypt
Thank u and have a good time بارك الله لك فى صحتك
[Aug 12, 2014 10:30:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    https://www.facebook.com/Ali.Elsayed.brakat [Link] Report threatening or abusive post: please login first  Go to top
MarcoH
Bonjour,
Merci pour votre excellent logiciel. wink
Serait-il possible, dans une future version de l’éditeur de textures (ou dans une future version de Sweet home 3D lui-même), de prévoir une rotation plus précise des textures.
En effet, il n'est proposé généralement que 0° ou 45° ou 90°.
J'ai modélisé ma (très) vielle maison, aucune pièce n'est carrée et/ou parallèle et/ou perpendiculaire à la grilles et j'ai donc un rendu de l'orientation du parquet non réaliste.
[Sep 3, 2015 4:48:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://marcodechaligny.free.fr/ [Link] Report threatening or abusive post: please login first  Go to top
SnakeGB
Hi not sure if this is still being developed or not but i notice a bug,
if i import textures say
i get under name
00
01
02
02
02
so if i import 100 textures i would have to rename all of them
[Oct 25, 2017 12:19:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Campi
Hi all,
First post here.
I seem to be missing a step or something. I've downloaded both the texture and the furniture library editors and I got a compressed file when opened, I get a folder with a bunch of meta files and a zipped jnlp.jar file
I'm running OS X 10.11.6 and the java site verified I am running Java 9.0.1
Thanks
[Nov 22, 2017 7:31:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
