Textures Library Editor released
This topic has been viewed 184598 times and has 20 replies
Thread status: Active
Test the features and bug fixes of future versions [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
User avatar
Country: Paris, France
Contact:
Re: Textures Library Editor released
Post by Puybaret »
MarcoH, rotating textures can be performed only in Sweet Home 3D, not in the Textures Library Editor. From version 5.5, you can set any angle.
SnakeGB, I'll see if I can improve the naming system in a future version of the Furniture Library Editor.
Campi, the Jar executable files shouldn't be unzipped, run them with Jar Launcher. Note that I don't think that the Furniture Library Editor can run with Java 9 under macOS at the moment, and you should rather run it under Java 8.
Campi
Country: USA
Post by Campi »
Thanks Puybaret
I've done some research since I posted and indeed el captain with java 9 has caused some problems with jars. For some reason 10.11 does not have the launcher from what i understand.
My next hurdle will be to to uninstall 9 (as it seams you can't install older versions over newer) since I'm not that proficient with the terminal haha
Thank you for the link since apple no longer supports legacy java
Thanks again
Campi
Country: USA
Post by Campi »
OK that did the trick java 8 installed. The jars still show as zip files but at least I can open with terminal.
Thank you Puybaret!!
Campi
Country: USA
Post by Campi »
Hi Again
I know I am missing something but just can't seem to get it to work.
I know this is a java/os problem but perhaps you might have some insight.
I got the texture and the furniture editors to open using the terminal but when I try to open a library I get nothing in the texture editor and the furniture editor crashes when opening a furniture lib.
I have tried all the versions of the editors and same thing happens.
I know this works because the furniture editor worked fine with 10.8
Again, any insight would be appreciated
User avatar
Contact:
Post by Puybaret »
What Java version is displayed in the About dialog (click on the light bulb at the end of the toolbar)?
Campi
Country: USA
Post by Campi »
1.5 for the Texture Lib Java version 9.0.1
I have also tried 1.3 and 1.4 both indicate Java 9.0.1
FPatrick
Country: France
Post by FPatrick »
Bonjour,
SH3D est toujours aussi plaisant à utiliser, Merci !
Je viens de mettre à jour Textures Library Editor avec la version 1.6. Mon système d'exploitation est Xubuntu, java version 11.0.6 est installé.
Je lance le soft sans problème, j'accède au menu « Ouvrir une bibliothèque de textures », je sélection une bibliothèque créée il y a deux ou trois ans (Ma_Bibliotheque_textures.sh3t)... et rien ne se passe.
Une idée ?
Merci par avance !
otadmin
Post by otadmin »
Has there been a solution to the problem? I am on Jave 11.0.8, LinuxMint 20 and the same happens here - empty texture editor.
otadmin
Post by otadmin »
Solved my problem by installing Texture Editor 1.6 from the Sweethome website. Version 1.6.2 in the repositories of LM20 not working.
Soulbrother
Post by Soulbrother »
A wish:
could you integrate the category in the Preferences, so that we can setup a category (new or existing).
OR
is there any other way, to avoid manual choosing and entering for each texture in one lib.?
Post Reply New Topic
Who is online
