Sweet Home 3D 4.0
This topic has been viewed 322970 times and has 136 replies
Thread status: Active
Test the features and bug fixes of future versions [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
User avatar
Groumphy
Country: Brussels, Belgium
Contact:
Re: Sweet Home 3D 4.0
Post by Groumphy »
Waw... Coming days are coming hours.
Yeah I'll agree for test the beta viewer ! I think you've my e-mail adress (groumphy on the domain GMail).
Or best is upload the beta version on SourceForge.
Groumphy
FR - NL - EN
robal
Post by robal »
Spotted a small bug (also in 3.7 if I remember correctly).
- when editing a wall color/texture, setting are not applied after clicking "OK" in "modify walls" dialog
repro:
1) set any side of the wall to any texture and close "modify walls" dialog
2) open "modify walls" dialog again, and change wall side to "color" (but without clicking the color picker button)
3) hit "OK"
4) the wall side is still textured
Cheers,
User avatar
Country: Paris, France
Contact:
Post by Puybaret »
It was just a small problem of some missing files in SweetHome3DViewer.jar file.
I've uploaded a beta version of the viewer here, to let you test.
User avatar
Groumphy
Contact:
Post by Groumphy »
Hello,
I've (endly) make the first test with the webviewer.
This work (for the load, the first view etc...) but I think there is a small problem with 2 thinks:
1. (most important I think) somes furnitures are in one block (no details) and colored in red ;
2. (minor) the height is not good, the code
Code: Select all
 width:"100%", height:"95%"};
is not understand by the browser...
I have one more idea for improvement: to have the level structure (tabs in SH3D) to have a first hand and not a global view.
You can view the actual problem on this link: myhome.zoyo.be.
I will check for the height and with in the Javascript and try to find a solution...
Success,
Xavier
(PS: for the test, I'm working on Ubuntu 12.04LTS, Mozilla Firefox 19.0.2, and Oracle Java 1.7.0.17 with the Firefox plugin 1.7.0.17)
Groumphy
FR - NL - EN
User avatar
Contact:
Post by Puybaret »
Thanks for your tests. [:)]
Red blocks generally means a problem with the 3D model file. I downloaded your sh3d file and it appears that the "22" file matching some red objects is incorrect in the sh3d file. I guess you should upload again your file on the server.
Code: Select all
Maybe it's because you included the applet script in a div tag.
Adding the levels tabs at the top of the 3D view shouldn't be too difficult. Please fill a feature request to ensure I don't forget it.
User avatar
Groumphy
Contact:
Post by Groumphy »
Hello,
Fantastic, the first "problem" is solved.
But the second for the height isn't...
The Javascript is now out of the DIV.
I think this is because JS send info about the applet this is not à block of HTML. But today I don't have time for look about this. I will try tomorow...
For the tab in the webview I'll introduce next time ;)
Enjoy,
Xavier
Groumphy
FR - NL - EN
User avatar
Groumphy
Contact:
Post by Groumphy »
Hello,
I've found a solution !
Define a width and height in pixel (for sample). Because if we define it in %, the heigth cannot be know by the browser... ;)
This is a W3C standard... and apply by Firefox.
Have a nice day,
Xavier
Groumphy
FR - NL - EN
User avatar
Groumphy
Contact:
Post by Groumphy »
Done [:p]
Have a nice day.
Groumphy
FR - NL - EN
User avatar
Contact:
Post by Puybaret »
Tonight, here's the last Beta (I hope) of Sweet Home 3D 4.0.
It brings the 16 translations available in the core version, and improvements in the aerial view mode, where the elevation of the rotation center is now at the half height of the items displayed in the 3D view when nothing is selected (underground items excepted), or at the half height of the selected item. Please, help to test it with as many weird cases as possible to ensure it behaves correctly.
Many thanks to all the contributors who translated the new words of this version. [:)]
User avatar
Contact:
Post by Puybaret »
Sorry, I discovered that the Beta 25 couldn't work when the new Aerial view centered on selection option was disabled. So, here's the Beta 26 and as a bonus a DMG file for Beta tests under Mac OS X.
Post Reply New Topic
Who is online
Users browsing this forum: Amazon [Bot]
