Sweet Home 3D 3.7 for Mac OS X bundled with Java 7
Here's a first beta version of Sweet Home 3D 3.7 bundled with Java 7 (74 MB). It should work under Mac OS X 10.6 to 10.8 (only 64 bits processor are supported under Mac OS X 10.6).
Note the following known bugs: - the top and the bottom of toolbar buttons are missing, - the top of titled sub panels in dialog is too small, - if the menu bar appears as empty when a document is opened, deactivate / reactivate the program to make it appear again (or open / close any dialog in the program), - no default menu is displayed when all Sweet Home 3D windows are closed, - there's no antialiasing in the 3D view. The 4 first ones are bugs in Java 7 and the last one is due to current version of Java 3D 1.6 which is not finalized yet.
[Note: on 12/18/2012, this beta version was replaced by a new one based on Sweet Home 3D 3.8 Beta]
[Edit 2 times,
last edit by Puybaret at Dec 18, 2012, 5:44:33 PM]
Re: Sweet Home 3D 3.7 for Mac OS X bundled with Java 7
I just updated the beta version (same link) to fix an issue that forbad to resize the main window.
