Previous Thread This topic has been viewed 18691 times and has 15 replies Next Thread
sputnam
Realistic hardwood floors?????????????
I downloaded some JPEG's of what looked like good hardwood floors but when I added them to Sweet Home it just looked like brown tiles. I've seen images of people having real hardwood floors but I can't find out how they did it. Any suggestions?
[Feb 7, 2013, 2:20:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Realistic hardwood floors?????????????
Have you looked at all these sites with textures ?
Have you searched Google ?
[Feb 7, 2013, 1:34:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sputnam
i got the textures from this site (textures tab to the left). I have googled my butt off. I SEE the pictures that have realitic hardwoods but no info on how to get them.
[Feb 7, 2013, 10:23:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You should check the size of the texture you entered at importation time. A too small size could give the result you described from far.
[Feb 8, 2013, 7:07:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sputnam
one of them is 1024 X 1024 and it still looks like 1' X 1' tile when imported.
[Feb 8, 2013, 11:54:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sputnam
i just tried making a wall 8' long and .125" tall and texturing that and "building" my floor piece by piece. I've just begun messing with it but it looks like it has potential.
[Feb 8, 2013, 12:13:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The size in pixel of the image is not the size you have to enter in the texture import wizard. The requested size is the size of the image in real life for example, 10x10 inches.
Walls are supposed to represent walls in real life. You'd rather create rooms and change the texture of their floor.
[Feb 8, 2013, 12:23:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Scott,
It seems you're taking the hard way to make a textured floor.
SH3D is designed to make this porcess real easy, as follows:
1 - draw your walls (and make sure end wall and start wall are locked or overlapping);
2 - double-click inside the walls to create a room;
3 - right-click the room and apply a texture (works the same for walls and rooms);
4 - if you don't have the right texture, click on Import and select the correct image;
This is described in detail in the User's guide. Maybe you haven't taken the time to read it?
[Feb 8, 2013, 12:31:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sputnam
Hans,
Yes, I have read the user's guide and followed the procedures just as you described but I am still not getting the effect I want. Do you have a picture of your 3D model with realistic hardwoods. I would love to see it. Also, as far as the size of the texture is concerned I have changed it from 1" to 20' and everything in between...still looks like tile. If anyone with suggestions on how to do would this please include a picture of your successful attempt I would really appreciate it. This is what I get:
This is what i want:
[Feb 8, 2013, 4:56:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
This texture gives the result below (if imported as 60x60 cms).
[Feb 8, 2013, 6:39:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
