Rendering does not use 100% CPU
It may be an odd question (and maybe better suited to Sunflow's forum), but:
Does anyone experience low CPU usage during rendering ? When I render, my CPU utilisation is at around 60% (javaw.exe process) I thought it should be almost 100%, since Sunflow creates a thread for each core.
I've tested this on two machines: - Core I7 860 (4 cores, 8 threads) - Phenom II 950 (4 cores, 4 threads)
I'm wondering whether it's something funny about my machines (or my SH3D scene).
Re: Rendering does not use 100% CPU
What Java version do you use? Could you try with the installer version and not the Java Web Start version, to see if it behaves the same?
Would you have any tool that would prevent a program to use all the CPU power?
