Problems because of low memory
I think I am pushing the limits of SweetHome. I have a 22,000 sq ft building with 3 floors and roofs. When tyring to take a photo with very high resolution, SW complains that memory is not enough after a while. I wonder if that problem could be solved by recompiling the program with a higher memory allocation. Would that be something "simple" to do?
Re: Problems because of low memory
There are simpler solutions. Look at the FAQHow can I adjust the memory used by Sweet Home 3D? and eventually this message.
