condo
Re: time of day in "Create photos at points of view"
The only way you can modify camera positions is by calling them up, making the desired changes and then saving them with the same name. I don't feel limited in any way.
I had a different problem with stored camera positions after moving my appartment to the proper level, I found out that all camera positions have been stored in the base level were I started with SH3D. Some simple math (room height + floor thickness x level) added to the camera height moved the camera to the proper position on the new level. Saved it with the same name and done (it is to be noted that the camera height is now again relative to the level, not the ground).
[Mar 2, 2014, 10:07:23 PM]
[Link]
