Previous Thread This topic has been viewed 2722 times and has 2 replies Next Thread
Badu
Sky becomes grey
Even when i changed in 3D my background in a clear blue sky, when i make a photo, the sky becomes grey.
I tried different scales of blue.
[Mar 6, 2014, 9:01:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Sky becomes grey
As explained in the help:
If you selected a color for the sky in the 3D view pane or if the current mode is Aerial view, a sky image computed according to the hour of the day is used for the rendering of the sky. If you chose a texture for the sky, that texture will always be used in Virtual visit mode whatever the selected hour.
I guess what you see isn't completely gray but is the bottom part of the sky image. If you want a plain color in the photo you create, you should use a texture image containing only that color for the sky (it doesn't have to be big, a image with a few pixels will be enough) .
[Mar 6, 2014, 9:33:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Badu
Hi Emmanuel,
But even when i choose color (i.s.o. texture) the sky is blue in the normal screen, but becomes grey when I make a photo.
[Mar 7, 2014, 9:18:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
