Total posts in this thread: 4
Previous Thread This topic has been viewed 3023 times and has 3 replies Next Thread
mohamed2015
egypt
how to put listello on the wall???
can any one tell me how to put listello on the wall pls want to put it Crosswise
[Apr 2, 2014, 12:18:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: how to put listello on the wall???
Mo,
If by "listello" you mean a narrow band of tiles, this is the easiest way:
1 - import the texture; make sure you give it the correct height in inches or centimeters;
2 - apply the texture to a box that has the same height as the texture;
3 - make the box as wide as you need, and give it the correct elevation;
4 - place it directly in front of the wall.
[Apr 2, 2014, 10:45:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mohamed2015
egypt
hello mr hans first thank you for reply to me but second if am do what you did told me that will make a shadow when am will make the picture 3d and am not want the listello tile make a shadow am want it be on the wall direct not in front of the wall
[Apr 2, 2014, 9:41:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Mo,
Let me explain again...
If you want a band of tiles 10 cms high (or 4 inches), make sure that your texture is 10 cms high, and that your box is 10 cms high.
Now give your box the correct length, say 250cms.
It is important that the box is as thin as possible, and that you place it flush against the wall. This way it looks as part of the wall, and will not cast a shadow.
[Apr 2, 2014, 11:07:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
