How to install SweetHome 3d on website
This topic has been viewed 25948 times and has 24 replies
Thread status: Active
Questions about Sweet Home 3D installation [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Just_MAX
Re: How to install SweetHome 3d on website
Post by Just_MAX »
Did it, thanks for pointing in right direction
Just_MAX
Post by Just_MAX »
I found PDF saving function doesn't work in my case, same as creating photo with date and time parameters,
any clues what is wrong?
User avatar
Country: Paris, France
Contact:
Post by Puybaret »
- If you want Print to PDF feature, you have to set enablePrintToPDF applet parameter to true, and add iText-2.1.7.jar signed library to jars list (in the applet parameters as well as in the JNLP file).
- If you want photo creation feature, you have to set enableCreatePhoto applet parameter to true, and add sunflow-0.07.3i.jar signed library to jars list.
- If you want video creation feature, you have to set enableCreateVideo applet parameter to true, and add jmf.jar signed library to jars list.
- If you want Export to SVG feature, you have to set enableExportToSVG applet parameter to true, and add freehep-vectorgraphics-svg-2.1.1b.jar signed library to jars list.
Look at the Online version on this web site for a real world example (requires that you are logged in).
Just_MAX
Post by Just_MAX »
Did it before, but keep receiving errors about jnlp files mismatch (checked - it was same, files cache renewed, java cache disabled)
And it worked after i sent you a message. Strange thing
efodi
Country: Hungary
Post by efodi »
Hi!
I have installed Java Version 8 Update 241 for using Sweet Home 3D online version, but i still receive the following error:
Unable to load resource: http://www.sweethome3d.com/lib/SweetHome3DApplet.jar
If i try independent to download the .jar i have no problem with it.
It looks like only the site it self has problem with his own .jar.
I'm using a Win10 with IE11.
Could somebody please help me here?
Thank you!
Post Reply New Topic
Who is online
