Cuba
Re: save scene
yes, of course, sorry, but I formulated the question wrongly. I really want to know is how i can add extra information to the .sh3d file. if I don´t make this from a plugin what way I need to follow.
Re: save scene
With a plug-in, the only way I can see could be using the setVisualProperty method in Home class. Be sure that all the objects you store there implements java.io.Serializable interface. Without a plug-in, you will have more freedom but it will be more complicated, since you will have to create a derived version of Sweet Home 3D, by subclassing SweetHome3D class, to override its getHomeRecorder method and return a different HomeRecorder instance. If you go that way, you can also override createHome to return a Home subclass instance of your choice.
