Total posts in this thread: 4
Previous Thread This topic has been viewed 4783 times and has 3 replies Next Thread
akuma
Cuba
confused save scene
Hi how I can call from a plugin to the methods to save the scene in .sh3d format. confused
[Apr 8, 2014, 4:25:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: save scene
What about the save method in HomeController class?
[Apr 8, 2014, 5:27:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
akuma
Cuba
Re: save scene
yes, of course, sorry, but I formulated the question wrongly. I really want to know is how i can add extra information to the .sh3d
file. if I don´t make this from a plugin what way I need to follow.
[Apr 10, 2014, 8:08:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: save scene
With a plug-in, the only way I can see could be using the setVisualProperty method in Home class. Be sure that all the objects you store there implements java.io.Serializable interface.
Without a plug-in, you will have more freedom but it will be more complicated, since you will have to create a derived version of Sweet Home 3D, by subclassing SweetHome3D class, to override its getHomeRecorder method and return a different HomeRecorder instance. If you go that way, you can also override createHome to return a Home subclass instance of your choice.
[Apr 11, 2014, 9:06:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
