Re: housing ideas
I think maybe you want to be a bit more specific to get a reply that makes sense. If you by serious mean you want to build a home, you could look through the gallery. You could also look at various (local) prefabricated homes, find one you like and use the plan as inspiration. The prefabricated houses are often well thought out in terms of local requirements. But clearly the initial layout is but a fraction of the actual architectural work needed. Also, beware of copyright.
