Re: swimming pool elevation
Depends how you design your pool and whether you use a model of a pool. Try using a negative level (Add Level, and edit it to the "bottom of the pool", say -220cm).
You can draw your pool as a room with walls on the negative (subterranean) level where the walls protrude above ground to form the edge of the pool.
Noticed the new blog post on how to design a swimming pool, with an example .sh3d file. Thanks, useful guidance to the basic steps of how to create a pool, using textures, curved walls and do model design with the help of SH3D. And a very nice design too.
