Features
Previous Thread This topic has been viewed 3782 times and has 2 replies Next Thread
choppyleo
Cameroon
angry Import 3D format
Hello, Is it possible to import 3D format directly into Sweet Home 3D software. Or if not yet how can it be done to add these function.
Thanks a lot!
[Jul 24, 2014 8:59:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Re: Import 3D format
Basically, you should decode the file format you want to import, then try to create Wall and Room instances that the imported data contains. Finally, add these objects to a new Home instance that you'll display at the screen by inspiring you from SweetHome3D main class source code.
[Jul 24, 2014 9:36:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
choppyleo
Cameroon
Thanks
But is there a code already on your reply?
I will love to have it and see how it is implemented.
[Jul 25, 2014 2:18:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
