Features
Total posts in this thread: 35
Posts: 35   Pages: 4   [ Previous Page | 1 2 3 4 | Next Page ]
Previous Thread This topic has been viewed 48772 times and has 34 replies Next Thread
adlerhn
Europe
Re: Tiny display in Win 8.1
-Dcom.eteks.sweethome3d.resolutionScale=2.5
-Dswing.defaultlaf=javax.swing.plaf.metal.MetalLookAndFeel
-Dswing.plaf.metal.controlFont=Dialog-11
-Dswing.plaf.metal.userFont=SansSerif-11
-Dswing.plaf.metal.systemFont=SansSerif-11
That works beautifully! I had set -Dcom.eteks.sweethome3d.resolutionScale=2, but some fonts were huge. I have now set the other parameters as suggested (keeping resolutionScale=2 though), and everything looks great.
[Jul 7, 2016 1:22:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message    http://www.nightearth.com [Link] Report threatening or abusive post: please login first  Go to top
hds
Belgiƫ
Is there a solution for the online version? I have a 4K lapop screen...
[Jul 11, 2016 4:41:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mtm216
Just to say that on Windows 10 on a Surface book I had the same issue, but this .ini file fix worked perfectly - Thanks
[Sep 11, 2016 12:38:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gavinx
I am running a Lenovo Yoga and am having the problems mentioned above.
After applying the SweetHome3D.l4j.ini fix I got some relief. Everything displays correctly except for the list of furniture items used in the plan - which is displayed as a list in the lower left panel of the screen.
This list is scrunched up.
Is there a fix for this?
Thanks
[Dec 10, 2016 1:40:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hi.
I made this change to sh3d and must say the text size is much better for me, but, if i open - close - reopen a separate function, eg, photo or create shape, each time i open it the text size enlarges until it becomes unusuable, any idea why this would be.
Thanks
[Jan 8, 2017 5:23:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Images might explain it better.
Normal
[Jan 8, 2017 5:46:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
rajeshdave
India
Solve the Problem thanks a lot is there any way to make the tools icons look bigger
Thank you
[Jan 12, 2017 10:02:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Mike, I found the bug you reported. It will be fixed in the next version. Thanks for reporting it smile
[Jan 18, 2017 12:12:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
Your the man biggrin
Sorry i keep finding them tongue
[Jan 18, 2017 6:17:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
As long as you report them (gently), it's not a problem! smile
[Jan 18, 2017 7:11:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
