Total posts in this thread: 7
Previous Thread This topic has been viewed 7487 times and has 6 replies Next Thread
maaheyindian
confused Sweet Home 3D with Java Web Start not working in java7
Tried in many ways, still no improvement (JNLPSigningException) java7 error retaining… Loosing hope.
Any help?
[Edit 1 times, last edit by Puybaret at Oct 10, 2014, 8:33:55 AM]
[Oct 9, 2014, 11:59:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Sweet Home 3D with Java Web Start not working in java7
This error means that the JNLP file you deployed isn't the same one as the one included in SweetHome3DJavaWebStart.jar file (see target javaWebStart in build.xml )
[Oct 10, 2014, 8:36:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
maaheyindian
Both files are same; really i don’t know what I am missing here. can you explain me how to get rid of this error..
[Oct 14, 2014, 1:03:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
maaheyindian
also working fine in java6...
[Oct 14, 2014, 1:04:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It's normal that it works with Java 6, since the verification with JNLP-INF/APPLICATION.JNLP file was introduced with Java 7.
[Oct 14, 2014, 2:56:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
maaheyindian
Please give me the right solution; I stuck up on this stage, need help to move forward.
[Oct 15, 2014, 10:29:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Do you really think that if I knew the solution, I wouldn't give it??? I gave you the hints I could guess, it's up to you to go forward now.
[Oct 15, 2014, 12:19:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
