cungchoi
Re: Sample plugin does not start
Right, I think my exe file is not up to date. Fine now though. BTW, I modified your plugin Compute Walls Surface for my purpose and just for it (being messy of course), still I post it here if anyone bother to test or use it. don't know how to attach a file
//version 25 Dec 2014 //- added ability to approximate curved walls //- added ability to work for multilevel building //- corrected slope walls //- filter openings substractions by Doors & windows only //- approximate doors & windows positions to prefer more inclusions. CAUTION: may have side effects when a door or windows is in vicinity of more than one wall on any level
package com.eteks.calculateWalls;
import java.awt.geom.Point2D; import java.lang.reflect.Method; import java.util.ArrayList;
import com.eteks.sweethome3d.model.HomePieceOfFurniture; import com.eteks.sweethome3d.model.Selectable; import com.eteks.sweethome3d.model.Wall; import com.eteks.sweethome3d.plugin.Plugin; import com.eteks.sweethome3d.plugin.PluginAction;
import javax.swing.JOptionPane;
class CalculateWallsAction extends PluginAction {
private final Plugin plugin;
public CalculateWallsAction(ClassLoader loader, Plugin plugin){ putPropertyValue(Property.NAME, "Compute walls' area"); putPropertyValue(Property.MENU, "Tools"); this.plugin = plugin; // Enables the action by default setEnabled(true); }
private void showInfo(float size) { String message = "The walls' area currently is: "+size+" m\u00B2."; if(size == 0) { message = "Please select at least one wall."; } JOptionPane.showMessageDialog(null, message); } private boolean inWall(Wall w, float x, float y) { //if(x >= Math.min(w.getXStart(), w.getXEnd()) && x <= Math.max(w.getXStart(), w.getXEnd()) && y >= Math.min(w.getYStart(), w.getYEnd()) && y <= Math.max(w.getYStart(), w.getYEnd())) float cmpRate = 0; //generalize- just one end near the wall surface, there are two cases: //case 1: an arc wall if(w.getArcExtent() != null) { float [] arcCircleCenter; float arcCircleRadius; try{ Method m = Wall.class.getDeclaredMethod("getArcCircleCenter"); //m.invoke(d);// throws java.lang.IllegalAccessException m.setAccessible(true);// Abracadabra arcCircleCenter = (float[]) m.invoke(w);// now its OK arcCircleRadius = (float)Point2D.distance(w.getXStart(), w.getYStart(), arcCircleCenter [0], arcCircleCenter [1]); cmpRate =(float)Point2D.distance(x,y,arcCircleCenter [0], arcCircleCenter [1])/arcCircleRadius; } catch (Exception e) { e.printStackTrace(); } } else { float dist2Start = (float)Point2D.distance(x,y,w.getXStart(), w.getYStart()); cmpRate = (dist2Start + (float)Point2D.distance(x,y,w.getXEnd(), w.getYEnd()))/w.getLength(); } if((cmpRate > 0.9)&&(cmpRate< 1.1)) return true; return false; }
@Override public void execute() { float size = 0; ArrayList<Wall> walls = new ArrayList<Wall>(); for(Selectable sel : plugin.getHome().getSelectedItems()) { if(sel instanceof Wall) { Wall wall = (Wall) sel; //if(wall.getArcExtent() == null) walls.add(wall); size += (wall.getHeight() + ((wall.getHeightAtEnd()==null)? wall.getHeight():wall.getHeightAtEnd()) )*wall.getLength()/2.0;
//substracts openings for(HomePieceOfFurniture furniture : plugin.getHome().getFurniture()) if(furniture.isDoorOrWindow() && wall.isAtLevel(furniture.getLevel()) && inWall(wall, furniture.getX(), furniture.getY())) size -= (furniture.getHeight()*furniture.getWidth()); } } size /= 10000; showInfo(size); } }
[Dec 26, 2014, 7:10:40 AM]
[Link]
