Features
Total posts in this thread: 4
Previous Thread This topic has been viewed 5086 times and has 3 replies Next Thread
link2akhil
India
Fastest possible photo-realistic rendering
First things first: Hats off to the developer and all co-developers/ contributors for making SH3D such an amazing piece of software!
I have been trying to fasten the speed at which photo-realistic images are created - here are the details:
SH3D Room size: 110 MB
# of lights in room: 2
CPU: Intel i7 4510U (2 Ghz)
RAM: 4 GB
Have extended SH3D memory utilization to 1GB
Made furniture objects not in the camera viewport invisible
Result: 42 seconds
My Question to this forum is: How much faster can I render photo-realistic images via SH3D, if I were to use better CPU on a server? What server specifications would you recommend?
Thanks in advance folks!
[Jan 14, 2015 4:35:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Re: Fastest possible photo-realistic rendering
Welcome to Sweet Home 3D forum.
The more cores your CPU will have, the faster the rendering will be computed.
It should be possible also to dispatch the computing of the image on more than a computer (or server), but this would require some changes in the program.
[Jan 15, 2015 5:31:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
link2akhil
India
Thanks Emmanuel. Will try with more cores, and keep the forum posted of the progress.
[Jan 16, 2015 4:09:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
slimpy
If you want to speed up image creation you can do any of the following:
- faster CPU (more cores, higher clock)
- fewer objects in the scene
- fewer light sources in the scene
- less detailed models (fewer polygons)
- fewer and smaller image textures, no transparency
- smaller image size (less pixels to be computed)
- desktop instead of notebook
- additional cooling
Many notebooks have cooling issues by design (little space, small fan). They tend to overheat with high CPU usage over an extended period of time. This results in either reduced CPU clock speed or even complete failure.
Put your notebook in the freezer when doing high-res renders wink
What makes you think that computing the image on a server would speed things up? Apart from not being able to run SH3D headless you also potentially share the server's resources with other users.
Unless you find a way to use a render farm (e.g. BURP) I would stick to your personal computer.
Best, slimpy
[Jan 16, 2015 3:03:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
