Total posts in this thread: 8
Previous Thread This topic has been viewed 4705 times and has 7 replies Next Thread
Lumaja
South Africa
FurnitureLibraryEditor error
Ubuntu 12.04
Sweet Home 3D ver. 4.5
Double click on “FurnitureLibraryEditor-1.14.jar” shows error:
FurnitureLibraryEditor-1.14.jar' is not marked as executable. If this was downloaded or copied from an untrusted source, it may be dangerous to run. For more details, read about the executable bit.
What should I do now?
[Jan 28, 2015, 1:47:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: FurnitureLibraryEditor error
Assuming you get the file from the download page, make sure you have Java installed and adjust Java settings to allow the library editor to run. See also thread 4794 and there are other discussions on various Java releases for Ubuntu in the forum. ok
[Jan 28, 2015, 2:52:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Lumaja
South Africa
I have Java installed and SH is working I think it is Java 7.
About adjust Java settings don't know how to do that,
I changed the .jar into .zip but I think is not much of use.
Went to properties Open with Open JDK Java 6 Runtime but the same error come up.
[Jan 30, 2015, 7:44:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
slimpy
This is probably a permission issue in Ubuntu.
Try to change the executable bit for FurnitureLibraryEditor-1.14.jar:
chmod +x FurnitureLibraryEditor-1.14.jar
Best,
slimpy
[Jan 30, 2015, 1:31:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Lumaja
South Africa
Thank you for your response.
Terminal result:
luis@luis-G41M-Combo:~$ chmod +x FurnitureLibraryEditor-1.14.jar
chmod: cannot access `FurnitureLibraryEditor-1.14.jar': No such file or directory
The file is in “Home, Sweet Home 3D ver. 4.5
How I use this on command?
[Jan 30, 2015, 2:37:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
slimpy
Switch to the directory first using the cd command:
cd <path_to_directory>
You can also change the file permissions in the properties dialog in your file manager (Dolphin, Konqueror, etc.).
Best, slimpy
[Jan 30, 2015, 3:17:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Easiest way to change Permissions in Ubuntu is:
- select file
- right-click and select Properties
- choose tab Permissions
- put a check in the box that says "Allow to run as program" (or something similar)
- close the window.
Now the file can be run as a program.
[Jan 30, 2015, 4:49:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Lumaja
South Africa
Thank you it worked
[Feb 1, 2015, 6:02:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
