Re: Cannot render in level 4 (best)
Where did the table come from? Wouldn't you have used a too large image as texture somewhere?
Turkey
I dont remember, I have too much objects imported from Sketchup, 3DMax etc.... But I am trying to render what I seen in this forum happens nothing. I am creating new file with only one table it hapens nothing to.
I've been trying your file on my iMac with no issue using -Xmx2250m. Could you try again with Sweet Home 3D version 4.6 and no SweetHome3D.l4j.ini file?
Would you use Turkish localization? Last week, after releasing the version 4.6, I found a bug that prevented to run the rendering at the best quality with Turkish localization. Correction will be available in the next version. Sorry for the issue. If you prefer to run Sweet Home 3D in Turkish, I can provide a patch if needed. Just open a bug ticket and I'll post the patch there.
[Edit 1 times,
last edit by Puybaret at Feb 9, 2015, 3:47:16 PM]
