Features
Previous Thread This topic has been viewed 7593 times and has 12 replies Next Thread
bugarski.nenad
arch on half round wall
does anyone know how can i make/drow arch on a half round wall? tnx
[Feb 8, 2015 11:09:37 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: arch on half round wall
After you have drawn a wall with correct endpoints, double-click (or select and Modify walls) to enter Arc extent in the wall properties. ok
[Feb 8, 2015 10:42:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
bugarski.nenad
that makes a half round wall. i know that. what i want is to make arch hole in that kind of wall...
[Feb 22, 2015 11:53:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
changoel
me too
[Jan 10, 2017 4:21:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
If I understand correctly, you want to do that ?
If yes, you can use the default object 'arch'.
if no, you must create two walls* which will export in obj format.
You import again the new object and when you see the green arrows, click on up right frame (front view) and then with the mouse and key shift click on the down green Arrow to have 90° and click enter...
You'll have your half arch, see the joined file below.
(*) First wall : standard
Second wall : same than first but 'arc extent' = 90° and joins the twice.
Attachment Half arch.obj (12572 bytes) (Download count: 89)
[Edit 2 times, last edit by bdfd at Jan 10, 2017 4:38:38 PM]
[Jan 10, 2017 4:22:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If you want to put the arch IN the curved wall, then i think you can create your wall, give it an arc, then position an arch , from the library, but turn the magnetism OFF, make the arch as big as is needed to create the opening.
[Jan 10, 2017 9:11:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Tried it and failed sorry, the opening that is created is rectangular, i will have a rethink.
[Jan 10, 2017 9:43:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
I managed to make some thing that might do you, or at least give you an idea how you might achieve what you desire, here is a link to a sh3d file.
[Jan 10, 2017 10:54:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Nice attempt Mike. Of course, this workaround will work more or less well, according to the width of the arch and the curve of the wall...
[Jan 15, 2017 3:20:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
I know EP, but its all i could think of sad
[Jan 15, 2017 7:30:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
