sweethome3d-4.6-linux-x64.tgz
I started with ./SweetHome3d, the splash screen is displayed and the application hang:
Java 3D: implicit antialiasing enabled java.lang.RuntimeException: cannot load system cursor: CopyDrop.32x32 at sun.awt.X11.XToolkit.lazilyLoadDesktopProperty(Unknown Source)
Caused by: java.lang.RuntimeException: failed to load system cursor: DnD.Cursor.CopyDrop : cannot load system cursor: CopyDrop.32x32 at java.awt.dnd.DragSource.load(Unknown Source)
Re: sweethome3d-4.6-linux-x64.tgz
The option you tried disables the 3D view, but the error you've got isn't bound to any 3D feature. I think the file you downloaded is buggy? Did you try to download Sweet Home 3D again?
That was my source ! I downloaded again, uncompressed in another folder, executed it but always the same error. Problem of graphic driver ? (mga200 is very old ...)
Try to search your error in Google. You might have interesting answers like this one.
I solved the problem like this: I modified the mgag200 option to 0 in the modesetting.conf file ! But I lost high resolution of my screen ... Many thanks to Emmanuel.
Thanks for your feedback. In the future version of Sweet Home 3D, there are some chances that under Linux and Windows, there will be an update of the version of Java3D, the library used for the 3D view. Please, try again once it will be released to see if it works better.
