Romania
Java version up to date
According to java.com they offer now version 8. I've tested SH3D v4.6 & v5.0beta with java 6,7 and 8. Empty or new plan are open correctly with jre1.8u45, but the previously created especially large one (>5M or >6M) don't show the menu, plan window, furniture window etc. The 3D window are showed instantly and correct. I think You can consider to switch to java v8 wile they don't offer support for older versions. For me (under debian) is not necessarily a problem but for others.
---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law (Greer's Third Law) When all else fails, read the instructions.Murphy's Law
Re: Java version up to date
I wanted to update Sweet Home 3D to Java 8 too, and made some tests. Unfortunately, as soon as you set a texture on a room, the plan don't get repainted anymore and the Java console displays the following exception:
Exception in thread "AWT-EventQueue-0" java.lang.InternalError: Surface not cachable at sun.java2d.xr.XRPaints$XRTexture.getAccSrcSurface(XRPaints.java:211) at sun.java2d.xr.XRPaints$XRTexture.isPaintValid(XRPaints.java:224) at sun.java2d.xr.XRPaints.isValid(XRPaints.java:75) at sun.java2d.xr.XRSurfaceData.getMaskFill(XRSurfaceData.java:205) at sun.java2d.SurfaceData.validatePipe(SurfaceData.java:631) at sun.java2d.xr.XRSurfaceData.validatePipe(XRSurfaceData.java:123) at sun.java2d.SunGraphics2D.validatePipe(SunGraphics2D.java:446) at sun.java2d.pipe.ValidatePipe.validate(ValidatePipe.java:55) at sun.java2d.pipe.ValidatePipe.fill(ValidatePipe.java:159) at sun.java2d.SunGraphics2D.fill(SunGraphics2D.java:2527) at com.eteks.sweethome3d.swing.PlanComponent.fillShape(PlanComponent.java:2876) at com.eteks.sweethome3d.swing.PlanComponent.paintRooms(PlanComponent.java:2834) at com.eteks.sweethome3d.swing.PlanComponent.paintHomeItems(PlanComponent.java:2641) at com.eteks.sweethome3d.swing.PlanComponent.paintContent(PlanComponent.java:2531) at com.eteks.sweethome3d.swing.PlanComponent.paintComponent(PlanComponent.java:1873) at javax.swing.JComponent.paint(JComponent.java:1056)
Hansmex reported to me that he encountered a similar problem which actually seems to match the following bug. As Oracle closed it because they couldn't reproduce it, I fear it's going to take a long time before Sweet Home 3D get delivered with a newer Java version under Linux!
This issue should be fixed in the version 5.3. Meanwhile, you can test the correction with the version 5.3 beta 7 available here.
Romania
I've tested the 5.3 beta 7 and work. I observe some latency in move items in 3D and in 2D. I modify some things like memory, default furniture and some menu text but that not affect the general way of run. I tray to have a "fresh" install: -rename /home/[user]/.eteks/sweethome3d to sweethome3d-j7 -restart SweetHome3D-j8_112 -open a file which was previously open and save as Apartment-j8 -set the Preferences --on 2D the texture of rooms not show but in 3D appear correctly -close the program -add all set of furniture, textures and plugins -reopen the same file but no change, no texture for rooms in 2D -revert to /home/[user]/.eteks/sweethome3d used with j7 -run SweetHome3D-j8_112 and Apartment-j8.sh3d -> All's OK . In sweethome3d folder I have the work folder with about 44 temp files and about 49 Furniture-3-----.pref files. I'm not very clear but hope You understand. Dorin
Romania
You're right! It was my fault. I forgot to set in preferences how to show the rooms. Now it's all OK
