rdorsch
sweethome3D crashes during startup
Hello, sind a few days SweetHome3D crashes on my Debian Linux 8.1 system. This applies both for version 4.5 which comes with Debian and version 5.0 which was just released. The problematic frame is from the same function for both versions:rd@blackbox:~/SW.nobackup/SweetHome3D-5.0$ ./SweetHome3D Java 3D: implicit antialiasing enabled # # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0x6d36aa95, pid=21455, tid=1835244352 # # JRE version: 6.0_45-b06 # Java VM: Java HotSpot(TM) Server VM (20.45-b01 mixed mode linux-x86 ) # Problematic frame: # C [i965_dri.so+0x35aa95] __driDriverGetExtensions_i965+0x60ba5 # # An error report file with more information is saved as: # /home/rd/SW.nobackup/SweetHome3D-5.0/hs_err_pid21455.log # # If you would like to submit a bug report, please visit: # http://java.sun.com/webapps/bugreport/crash.jsp # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. # Aborted rd@blackbox:~/SW.nobackup/SweetHome3D-5.0$
This shows the error report rd@blackbox:~/SW.nobackup/SweetHome3D-5.0$ cat /home/rd/SW.nobackup/SweetHome3D-5.0/hs_err_pid21455.log # # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0x6d36aa95, pid=21455, tid=1835244352 # # JRE version: 6.0_45-b06 # Java VM: Java HotSpot(TM) Server VM (20.45-b01 mixed mode linux-x86 ) # Problematic frame: # C [i965_dri.so+0x35aa95] __driDriverGetExtensions_i965+0x60ba5 # # If you would like to submit a bug report, please visit: # http://java.sun.com/webapps/bugreport/crash.jsp # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. # --------------- T H R E A D --------------- Current thread (0x6f105400): JavaThread "J3D-Renderer-1" [_thread_in_native, id=21480, stack(0x6d5e9000,0x6d63a000)] siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR), si_addr=0x000001a4 Registers: EAX=0x00000000, EBX=0x6d5cb000, ECX=0x00000001, EDX=0x6c945a80 ESP=0x6d638bb0, EBP=0x6c945a80, ESI=0x6c90002c, EDI=0x6c945a80 EIP=0x6d36aa95, EFLAGS=0x00210246, CR2=0x000001a4 Top of Stack: (sp=0x6d638bb0) 0x6d638bb0: 6d139ac7 6d5cb000 ffffffff 6d32567b 0x6d638bc0: 6c90002c 6c945a80 00000000 00000000 0x6d638bd0: 0000000b 00000000 ffffffff 6d327d1c 0x6d638be0: 6c9f6c10 00000000 6d3255a9 5888a400 0x6d638bf0: 6c90002c 6c931af8 6d36a9d9 6d5cb000 0x6d638c00: 6c90002c 00000012 00000000 6d31aa19 0x6d638c10: 6c90002c 00000012 00000000 416fffff 0x6d638c20: 6c9f6c10 6c90002c 6c90002c 6d139b45 Instructions: (pc=0x6d36aa95) 0x6d36aa75: 00 00 00 00 00 c7 86 ac 01 02 00 00 00 00 00 c7 0x6d36aa85: 44 24 08 00 00 00 00 eb 72 66 90 89 d5 8b 47 60 0x6d36aa95: 8b 88 a4 01 00 00 85 c9 0f 84 fd 06 00 00 85 ed 0x6d36aaa5: c7 44 24 2c 00 00 00 00 c7 44 24 30 00 00 00 00 Register to memory mapping: EAX=0x00000000 is an unknown value EBX=0x6d5cb000: <offset 0x5bb000> in /usr/lib/i386-linux-gnu/dri/i965_dri.so at 0x6d010000 ECX=0x00000001 is an unknown value EDX=0x6c945a80 is an unknown value ESP=0x6d638bb0 is pointing into the stack for thread: 0x6f105400 EBP=0x6c945a80 is an unknown value ESI=0x6c90002c is an unknown value EDI=0x6c945a80 is an unknown value Stack: [0x6d5e9000,0x6d63a000], sp=0x6d638bb0, free space=318k Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code) C [i965_dri.so+0x35aa95] __driDriverGetExtensions_i965+0x60ba5 Java frames: (J=compiled Java code, j=interpreted, Vv=VM code) j javax.media.j3d.NativePipeline.clear(JFFFZ)V+0 j javax.media.j3d.NativePipeline.clear(Ljavax/media/j3d/Context;FFFZ)V+12 j javax.media.j3d.Canvas3D.clear(Ljavax/media/j3d/Context;FFFZ)V+10 j javax.media.j3d.Canvas3D.clear(Ljavax/media/j3d/BackgroundRetained;II)V+51 j javax.media.j3d.Renderer.doWork(J)V+4968 j javax.media.j3d.J3dThread.run()V+19 v ~StubRoutines::call_stub --------------- P R O C E S S --------------- Java Threads: ( => current thread ) 0x6f119400 JavaThread "J3D-InputDeviceScheduler-1" [_thread_blocked, id=21497, stack(0x6c2f2000,0x6c343000)] 0x6f117c00 JavaThread "J3D-SoundSchedulerUpdateThread-1" [_thread_blocked, id=21496, stack(0x6c343000,0x6c394000)] 0x6f116400 JavaThread "J3D-RenderStructureUpdateThread-1" [_thread_blocked, id=21495, stack(0x6c394000,0x6c3e5000)] 0x6f114c00 JavaThread "J3D-BehaviorScheduler-1" [_thread_blocked, id=21494, stack(0x6c3e5000,0x6c436000)] 0x6f113c00 JavaThread "J3D-TransformStructureUpdateThread-1" [_thread_blocked, id=21493, stack(0x6c436000,0x6c487000)] 0x6f112800 JavaThread "J3D-RenderingEnvironmentStructureUpdateThread-1" [_thread_blocked, id=21492, stack(0x6c487000,0x6c4d8000)] 0x6f111800 JavaThread "J3D-SoundStructureUpdateThread-1" [_thread_blocked, id=21491, stack(0x6c60d000,0x6c65e000)] 0x6f110800 JavaThread "J3D-GeometryStructureUpdateThread-1" [_thread_blocked, id=21490, stack(0x6c65e000,0x6c6af000)] 0x6f110000 JavaThread "J3D-BehaviorStructureUpdateThread-1" [_thread_blocked, id=21489, stack(0x6d935000,0x6d986000)] 0x094dd800 JavaThread "TimerQueue" daemon [_thread_blocked, id=21488, stack(0x6c6af000,0x6c700000)] 0x08b81c00 JavaThread "Image Fetcher 1" daemon [_thread_blocked, id=21485, stack(0x6ca5e000,0x6caaf000)] 0x08b88800 JavaThread "Image Fetcher 0" daemon [_thread_blocked, id=21484, stack(0x6caaf000,0x6cb00000)] 0xb6705400 JavaThread "DestroyJavaVM" [_thread_blocked, id=21458, stack(0xb685a000,0xb68ab000)] 0x6dc45800 JavaThread "autoSaveTimer" daemon [_thread_blocked, id=21483, stack(0x6cc7e000,0x6cccf000)] 0x6dcbcc00 JavaThread "Timer-2" daemon [_thread_blocked, id=21482, stack(0x6ce17000,0x6ce68000)] 0x6dcc5000 JavaThread "Timer-1" daemon [_thread_blocked, id=21481, stack(0x6ce68000,0x6ceb9000)] =>0x6f105400 JavaThread "J3D-Renderer-1" [_thread_in_native, id=21480, stack(0x6d5e9000,0x6d63a000)] 0x6dc36800 JavaThread "J3D-MasterControl-1" [_thread_blocked, id=21479, stack(0x6d63a000,0x6d68b000)] 0x6dc33400 JavaThread "J3D-NotificationThread" [_thread_blocked, id=21478, stack(0x6d68b000,0x6d6dc000)] 0x6dc32c00 JavaThread "J3D-TimerThread" [_thread_blocked, id=21477, stack(0x6d6dc000,0x6d72d000)] 0x6dc32400 JavaThread "J3D-RenderingAttributesStructureUpdateThread" [_thread_blocked, id=21476, stack(0x6d72d000,0x6d77e000)] 0x6dc19000 JavaThread "pool-2-thread-1" [_thread_in_native, id=21475, stack(0x6d8e4000,0x6d935000)] 0x6dc11800 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=21473, stack(0x6d9d5000,0x6da26000)] 0x6dc0f400 JavaThread "AWT-Shutdown" [_thread_blocked, id=21472, stack(0x6da26000,0x6da77000)] 0x6dc04c00 JavaThread "AWT-XAWT" daemon [_thread_in_native, id=21471, stack(0x6da77000,0x6dac8000)] 0x6e995800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=21470, stack(0x6dec0000,0x6df11000)] 0xb67bb000 JavaThread "Timer-0" daemon [_thread_blocked, id=21469, stack(0x6e88a000,0x6e8db000)] 0xb6798800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=21467, stack(0x6eaa0000,0x6eaf1000)] 0xb6797000 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=21466, stack(0x6eaf1000,0x6eb72000)] 0xb6795000 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=21465, stack(0x6eb72000,0x6ebf3000)] 0xb6793400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=21464, stack(0x6ebf3000,0x6ec44000)] 0xb6786800 JavaThread "Finalizer" daemon [_thread_blocked, id=21463, stack(0x6ec44000,0x6ec95000)] 0xb6785000 JavaThread "Reference Handler" daemon [_thread_blocked, id=21462, stack(0x6ec95000,0x6ece6000)] Other Threads: 0xb6781400 VMThread [stack: 0x6ece6000,0x6ed67000] [id=21461] 0xb679a800 WatcherThread [stack: 0x6ea1f000,0x6eaa0000] [id=21468] VM state:not at safepoint (normal execution) VM Mutex/Monitor currently owned by a thread: None Heap PSYoungGen total 35072K, used 1177K [0x9e0d0000, 0xa05b0000, 0xb3620000) eden space 32384K, 3% used [0x9e0d0000,0x9e1f6730,0xa0070000) from space 2688K, 0% used [0xa0070000,0xa0070000,0xa0310000) to space 2688K, 0% used [0xa0310000,0xa0310000,0xa05b0000) PSOldGen total 43136K, used 7071K [0x73620000, 0x76040000, 0x9e0d0000) object space 43136K, 16% used [0x73620000,0x73d07fa8,0x76040000) PSPermGen total 36864K, used 20565K [0x6f620000, 0x71a20000, 0x73620000) object space 36864K, 55% used [0x6f620000,0x70a35650,0x71a20000) Code Cache [0xb36ef000, 0xb392f000, 0xb66ef000) total_blobs=624 nmethods=208 adapters=370 free_code_cache=49447488 largest_free_block=11200 Dynamic libraries: 08048000-08052000 r-xp 00000000 08:30 3671121 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/bin/java 08052000-08053000 rwxp 00009000 08:30 3671121 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/bin/java 089de000-095d7000 rwxp 00000000 00:00 0 [heap] 6af67000-6b200000 rwxp 00000000 00:00 0 6b200000-6b257000 rwxp 00000000 00:00 0 6b257000-6b300000 ---p 00000000 00:00 0 6b385000-6c28a000 rwxp 00000000 00:00 0 6c28a000-6c2bf000 r-xp 00000000 08:30 4587669 /usr/lib/i386-linux-gnu/libtxc_dxtn_s2tc.so.0.0.0 6c2bf000-6c2c0000 r-xp 00034000 08:30 4587669 /usr/lib/i386-linux-gnu/libtxc_dxtn_s2tc.so.0.0.0 6c2c0000-6c2c1000 rwxp 00035000 08:30 4587669 /usr/lib/i386-linux-gnu/libtxc_dxtn_s2tc.so.0.0.0 6c2f2000-6c2f5000 ---p 00000000 00:00 0 6c2f5000-6c343000 rwxp 00000000 00:00 0 [stack:21497] 6c343000-6c346000 ---p 00000000 00:00 0 6c346000-6c394000 rwxp 00000000 00:00 0 [stack:21496] 6c394000-6c397000 ---p 00000000 00:00 0 6c397000-6c3e5000 rwxp 00000000 00:00 0 [stack:21495] 6c3e5000-6c3e8000 ---p 00000000 00:00 0 6c3e8000-6c436000 rwxp 00000000 00:00 0 [stack:21494] 6c436000-6c439000 ---p 00000000 00:00 0 6c439000-6c487000 rwxp 00000000 00:00 0 [stack:21493] 6c487000-6c48a000 ---p 00000000 00:00 0 6c48a000-6c4d8000 rwxp 00000000 00:00 0 [stack:21492] 6c4d8000-6c4ed000 r-xp 00000000 08:30 3670512 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libdcpr.so 6c4ed000-6c500000 rwxp 00014000 08:30 3670512 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libdcpr.so 6c500000-6c5eb000 rwxp 00000000 00:00 0 6c5eb000-6c600000 ---p 00000000 00:00 0 6c60d000-6c610000 ---p 00000000 00:00 0 6c610000-6c65e000 rwxp 00000000 00:00 0 [stack:21491] 6c65e000-6c661000 ---p 00000000 00:00 0 6c661000-6c6af000 rwxp 00000000 00:00 0 [stack:21490] 6c6af000-6c6b2000 ---p 00000000 00:00 0 6c6b2000-6c700000 rwxp 00000000 00:00 0 [stack:21488] 6c700000-6c7ff000 rwxp 00000000 00:00 0 6c7ff000-6c800000 ---p 00000000 00:00 0 6c800000-6c8fa000 rwxp 00000000 00:00 0 6c8fa000-6c900000 ---p 00000000 00:00 0 6c900000-6c9f7000 rwxp 00000000 00:00 0 6c9f7000-6ca00000 ---p 00000000 00:00 0 6ca0e000-6ca18000 r-xs 00000000 08:30 4070179 /var/cache/fontconfig/6aa41aa22e18b8fa06a12da28ea9c28b-le32d4.cache-4 6ca18000-6ca20000 r-xs 00000000 08:30 4074331 /var/cache/fontconfig/945677eb7aeaf62f1d50efc3fb3ec7d8-le32d4.cache-4 6ca20000-6ca4f000 r-xs 00000000 08:30 4102687 /var/cache/fontconfig/365b55f210c0a22e9a19e35191240f32-le32d4.cache-4 6ca5e000-6ca61000 ---p 00000000 00:00 0 6ca61000-6caaf000 rwxp 00000000 00:00 0 [stack:21485] 6caaf000-6cab2000 ---p 00000000 00:00 0 6cab2000-6cb00000 rwxp 00000000 00:00 0 [stack:21484] 6cb00000-6cbf9000 rwxp 00000000 00:00 0 6cbf9000-6cc00000 ---p 00000000 00:00 0 6cc02000-6cc04000 r-xs 00000000 08:30 4105968 /var/cache/fontconfig/f24b2111ab8703b4e963115a8cf14259-le32d4.cache-4 6cc04000-6cc08000 r-xs 00000000 08:30 4105962 /var/cache/fontconfig/a46337af8a0b4c9b317ad981ec3bdf87-le32d4.cache-4 6cc08000-6cc0d000 r-xs 00000000 08:30 4102469 /var/cache/fontconfig/6eb3985aa4124903f6ff08ba781cd364-le32d4.cache-4 6cc0d000-6cc16000 r-xs 00000000 08:30 4105907 /var/cache/fontconfig/6d41288fd70b0be22e8c3a91e032eec0-le32d4.cache-4 6cc16000-6cc19000 r-xs 00000000 08:30 4102475 /var/cache/fontconfig/c57959a16110560c8d0fcea73374aeeb-le32d4.cache-4 6cc19000-6cc1e000 r-xs 00000000 08:30 4102353 /var/cache/fontconfig/3047814df9a2f067bd2d96a2b9c36e5a-le32d4.cache-4 6cc1e000-6cc20000 r-xs 00000000 08:30 4101724 /var/cache/fontconfig/de9486f0b47a4d768a594cb4198cb1c6-le32d4.cache-4 6cc20000-6cc30000 r-xs 00000000 08:30 4102131 /var/cache/fontconfig/d52a8644073d54c13679302ca1180695-le32d4.cache-4 6cc30000-6cc36000 r-xs 00000000 08:30 4102020 /var/cache/fontconfig/105b9c7e6f0a4f82d8c9b6e39c52c6f9-le32d4.cache-4 6cc36000-6cc3e000 r-xs 00000000 08:30 4067483 /var/cache/fontconfig/3f7329c5293ffd510edef78f73874cfd-le32d4.cache-4 6cc3e000-6cc47000 r-xs 00000000 08:30 4074311 /var/cache/fontconfig/d589a48862398ed80a3d6066f4f56f4c-le32d4.cache-4 6cc47000-6cc50000 r-xs 00000000 08:30 4072618 /var/cache/fontconfig/83bf95040141907cd45bb53cf7c1c148-le32d4.cache-4 6cc50000-6cc60000 r-xs 00000000 08:30 4072605 /var/cache/fontconfig/4ac51e5cfbc76fc3f983e470323a16d3-le32d4.cache-4 6cc66000-6cc76000 rwxs 114f6000 00:05 8842 /dev/dri/card0 6cc76000-6cc7d000 r-xp 00000000 08:30 3670539 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libnio.so 6cc7d000-6cc7e000 rwxp 00006000 08:30 3670539 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libnio.so 6cc7e000-6cc81000 ---p 00000000 00:00 0 6cc81000-6cccf000 rwxp 00000000 00:00 0 [stack:21483] 6cccf000-6ccd2000 r-xs 00000000 08:30 4102333 /var/cache/fontconfig/e49e89034d371f0f9de17aab02136486-le32d4.cache-4 6ccd2000-6ccd4000 r-xs 00000000 08:30 4102293 /var/cache/fontconfig/4b14b093aebc79c320de5e86ae1d3314-le32d4.cache-4 6ccd4000-6ccea000 r-xs 00000000 08:30 4101986 /var/cache/fontconfig/e13b20fdb08344e0e664864cc2ede53d-le32d4.cache-4 6ccea000-6cd00000 r-xs 00000000 08:30 4067640 /var/cache/fontconfig/467c019e582ee353435ea5c21d137ef6-le32d4.cache-4 6cd00000-6cdff000 rwxp 00000000 00:00 0 6cdff000-6ce00000 ---p 00000000 00:00 0 6ce01000-6ce04000 r-xs 00000000 08:30 4074180 /var/cache/fontconfig/75114ca45c98e8a441da0ff356701271-le32d4.cache-4 6ce04000-6ce06000 r-xs 00000000 08:30 4101966 /var/cache/fontconfig/7ef2298fde41cc6eeb7af42e48b7d293-le32d4.cache-4 6ce06000-6ce10000 r-xs 00000000 08:30 4067775 /var/cache/fontconfig/8f02d4cb045bd6ce15663e43f347c9f8-le32d4.cache-4 6ce10000-6ce17000 r-xs 00000000 08:30 4855115 /home/rd/.cache/fontconfig/409b9aba07a9981b84a296992d08e6b3-le32d4.cache-4 6ce17000-6ce1a000 ---p 00000000 00:00 0 6ce1a000-6ce68000 rwxp 00000000 00:00 0 [stack:21482] 6ce68000-6ce6b000 ---p 00000000 00:00 0 6ce6b000-6ceb9000 rwxp 00000000 00:00 0 [stack:21481] 6ceb9000-6cec2000 r-xp 00000000 08:30 4591442 /usr/lib/i386-linux-gnu/libpciaccess.so.0.11.1 6cec2000-6cec4000 r-xp 00009000 08:30 4591442 /usr/lib/i386-linux-gnu/libpciaccess.so.0.11.1 6cec4000-6cec5000 rwxp 0000b000 08:30 4591442 /usr/lib/i386-linux-gnu/libpciaccess.so.0.11.1 6cec5000-6cee1000 r-xp 00000000 08:30 4980934 /lib/i386-linux-gnu/libgcc_s.so.1 6cee1000-6cee2000 rwxp 0001b000 08:30 4980934 /lib/i386-linux-gnu/libgcc_s.so.1 6cee2000-6cfc8000 r-xp 00000000 08:30 4587846 /usr/lib/i386-linux-gnu/libstdc++.so.6.0.20 6cfc8000-6cfcc000 r-xp 000e6000 08:30 4587846 /usr/lib/i386-linux-gnu/libstdc++.so.6.0.20 6cfcc000-6cfcd000 rwxp 000ea000 08:30 4587846 /usr/lib/i386-linux-gnu/libstdc++.so.6.0.20 6cfcd000-6cfd4000 rwxp 00000000 00:00 0 6cfd4000-6cfe1000 r-xp 00000000 08:30 4588602 /usr/lib/i386-linux-gnu/libdrm_radeon.so.1.0.1 6cfe1000-6cfe2000 r-xp 0000c000 08:30 4588602 /usr/lib/i386-linux-gnu/libdrm_radeon.so.1.0.1 6cfe2000-6cfe3000 rwxp 0000d000 08:30 4588602 /usr/lib/i386-linux-gnu/libdrm_radeon.so.1.0.1 6cfe3000-6cfe9000 r-xp 00000000 08:30 4589595 /usr/lib/i386-linux-gnu/libdrm_nouveau.so.2.0.0 6cfe9000-6cfea000 r-xp 00005000 08:30 4589595 /usr/lib/i386-linux-gnu/libdrm_nouveau.so.2.0.0 6cfea000-6cfeb000 rwxp 00006000 08:30 4589595 /usr/lib/i386-linux-gnu/libdrm_nouveau.so.2.0.0 6cfeb000-6d00e000 r-xp 00000000 08:30 4589873 /usr/lib/i386-linux-gnu/libdrm_intel.so.1.0.0 6d00e000-6d00f000 r-xp 00022000 08:30 4589873 /usr/lib/i386-linux-gnu/libdrm_intel.so.1.0.0 6d00f000-6d010000 rwxp 00023000 08:30 4589873 /usr/lib/i386-linux-gnu/libdrm_intel.so.1.0.0 6d010000-6d5ba000 r-xp 00000000 08:30 4588690 /usr/lib/i386-linux-gnu/dri/i965_dri.so 6d5ba000-6d5cb000 r-xp 005aa000 08:30 4588690 /usr/lib/i386-linux-gnu/dri/i965_dri.so 6d5cb000-6d5cf000 rwxp 005bb000 08:30 4588690 /usr/lib/i386-linux-gnu/dri/i965_dri.so 6d5cf000-6d5d7000 rwxp 00000000 00:00 0 6d5d7000-6d5e7000 r-xp 00000000 08:30 4981632 /lib/i386-linux-gnu/libudev.so.1.5.0 6d5e7000-6d5e8000 r-xp 0000f000 08:30 4981632 /lib/i386-linux-gnu/libudev.so.1.5.0 6d5e8000-6d5e9000 rwxp 00010000 08:30 4981632 /lib/i386-linux-gnu/libudev.so.1.5.0 6d5e9000-6d5ec000 ---p 00000000 00:00 0 6d5ec000-6d63a000 rwxp 00000000 00:00 0 [stack:21480] 6d63a000-6d63d000 ---p 00000000 00:00 0 6d63d000-6d68b000 rwxp 00000000 00:00 0 [stack:21479] 6d68b000-6d68e000 ---p 00000000 00:00 0 6d68e000-6d6dc000 rwxp 00000000 00:00 0 [stack:21478] 6d6dc000-6d6df000 ---p 00000000 00:00 0 6d6df000-6d72d000 rwxp 00000000 00:00 0 [stack:21477] 6d72d000-6d730000 ---p 00000000 00:00 0 6d730000-6d77e000 rwxp 00000000 00:00 0 [stack:21476] 6d77e000-6d78b000 r-xp 00000000 08:30 4587715 /usr/lib/i386-linux-gnu/libdrm.so.2.4.0 6d78b000-6d78c000 r-xp 0000c000 08:30 4587715 /usr/lib/i386-linux-gnu/libdrm.so.2.4.0 6d78c000-6d78d000 rwxp 0000d000 08:30 4587715 /usr/lib/i386-linux-gnu/libdrm.so.2.4.0 6d78d000-6d792000 r-xp 00000000 08:30 4591292 /usr/lib/i386-linux-gnu/libXxf86vm.so.1.0.0 6d792000-6d793000 r-xp 00004000 08:30 4591292 /usr/lib/i386-linux-gnu/libXxf86vm.so.1.0.0 6d793000-6d794000 rwxp 00005000 08:30 4591292 /usr/lib/i386-linux-gnu/libXxf86vm.so.1.0.0 6d794000-6d795000 r-xp 00000000 08:30 4593072 /usr/lib/i386-linux-gnu/libxshmfence.so.1.0.0 6d795000-6d796000 r-xp 00000000 08:30 4593072 /usr/lib/i386-linux-gnu/libxshmfence.so.1.0.0 6d796000-6d797000 rwxp 00001000 08:30 4593072 /usr/lib/i386-linux-gnu/libxshmfence.so.1.0.0 6d797000-6d79c000 r-xp 00000000 08:30 4595816 /usr/lib/i386-linux-gnu/libxcb-sync.so.1.0.0 6d79c000-6d79d000 r-xp 00005000 08:30 4595816 /usr/lib/i386-linux-gnu/libxcb-sync.so.1.0.0 6d79d000-6d79e000 rwxp 00006000 08:30 4595816 /usr/lib/i386-linux-gnu/libxcb-sync.so.1.0.0 6d79e000-6d7a0000 r-xp 00000000 08:30 4599509 /usr/lib/i386-linux-gnu/libxcb-present.so.0.0.0 6d7a0000-6d7a1000 r-xp 00001000 08:30 4599509 /usr/lib/i386-linux-gnu/libxcb-present.so.0.0.0 6d7a1000-6d7a2000 rwxp 00002000 08:30 4599509 /usr/lib/i386-linux-gnu/libxcb-present.so.0.0.0 6d7a2000-6d7a4000 r-xp 00000000 08:30 4595825 /usr/lib/i386-linux-gnu/libxcb-dri3.so.0.0.0 6d7a4000-6d7a5000 r-xp 00001000 08:30 4595825 /usr/lib/i386-linux-gnu/libxcb-dri3.so.0.0.0 6d7a5000-6d7a6000 rwxp 00002000 08:30 4595825 /usr/lib/i386-linux-gnu/libxcb-dri3.so.0.0.0 6d7a6000-6d7aa000 r-xp 00000000 08:30 4589871 /usr/lib/i386-linux-gnu/libxcb-dri2.so.0.0.0 6d7aa000-6d7ab000 r-xp 00003000 08:30 4589871 /usr/lib/i386-linux-gnu/libxcb-dri2.so.0.0.0 6d7ab000-6d7ac000 rwxp 00004000 08:30 4589871 /usr/lib/i386-linux-gnu/libxcb-dri2.so.0.0.0 6d7ac000-6d7c4000 r-xp 00000000 08:30 4593981 /usr/lib/i386-linux-gnu/libxcb-glx.so.0.0.0 6d7c4000-6d7c5000 r-xp 00018000 08:30 4593981 /usr/lib/i386-linux-gnu/libxcb-glx.so.0.0.0 6d7c5000-6d7c6000 rwxp 00019000 08:30 4593981 /usr/lib/i386-linux-gnu/libxcb-glx.so.0.0.0 6d7c6000-6d7d7000 r-xp 00000000 08:30 4590012 /usr/lib/i386-linux-gnu/libglapi.so.0.0.0 6d7d7000-6d7d9000 r-xp 00011000 08:30 4590012 /usr/lib/i386-linux-gnu/libglapi.so.0.0.0 6d7d9000-6d7de000 rwxp 00013000 08:30 4590012 /usr/lib/i386-linux-gnu/libglapi.so.0.0.0 6d7de000-6d7df000 rwxp 00000000 00:00 0 6d7df000-6d805000 r-xp 00000000 08:30 4981014 /lib/i386-linux-gnu/libexpat.so.1.6.0 6d805000-6d807000 r-xp 00026000 08:30 4981014 /lib/i386-linux-gnu/libexpat.so.1.6.0 6d807000-6d808000 rwxp 00028000 08:30 4981014 /lib/i386-linux-gnu/libexpat.so.1.6.0 6d808000-6d8ab000 r-xp 00000000 08:30 4588099 /usr/lib/i386-linux-gnu/libGL.so.1.2.0 6d8ab000-6d8ae000 r-xp 000a2000 08:30 4588099 /usr/lib/i386-linux-gnu/libGL.so.1.2.0 6d8ae000-6d8b3000 rwxp 000a5000 08:30 4588099 /usr/lib/i386-linux-gnu/libGL.so.1.2.0 6d8b4000-6d8b6000 r-xs 00000000 08:30 4068735 /var/cache/fontconfig/452f1fac34b224105d7acfae3034bcd5-le32d4.cache-4 6d8b6000-6d8d1000 r-xs 01994000 08:30 2787383 /home/rd/.eteks/sweethome3d/work/5000-48572d90-df59-426f-8bd5-19d2817b495c/temp227639058824280334.sh3f 6d8d1000-6d8e4000 r-xs 01dca000 08:30 2787382 /home/rd/.eteks/sweethome3d/work/5000-48572d90-df59-426f-8bd5-19d2817b495c/temp4249368795919155066.sh3f 6d8e4000-6d8e7000 ---p 00000000 00:00 0 6d8e7000-6d935000 rwxp 00000000 00:00 0 [stack:21475] 6d935000-6d938000 ---p 00000000 00:00 0 6d938000-6d986000 rwxp 00000000 00:00 0 [stack:21489] 6d986000-6d9d5000 rwxs 00000000 00:04 35946665 /SYSV00000000 (deleted) 6d9d5000-6d9d8000 ---p 00000000 00:00 0 6d9d8000-6da26000 rwxp 00000000 00:00 0 [stack:21473] 6da26000-6da29000 ---p 00000000 00:00 0 6da29000-6da77000 rwxp 00000000 00:00 0 [stack:21472] 6da77000-6da7a000 ---p 00000000 00:00 0 6da7a000-6dac8000 rwxp 00000000 00:00 0 [stack:21471] 6dac8000-6dacd000 r-xp 00000000 08:30 4593310 /usr/lib/i386-linux-gnu/libXfixes.so.3.1.0 6dacd000-6dace000 r-xp 00004000 08:30 4593310 /usr/lib/i386-linux-gnu/libXfixes.so.3.1.0 6dace000-6dacf000 rwxp 00005000 08:30 4593310 /usr/lib/i386-linux-gnu/libXfixes.so.3.1.0 6dacf000-6dad0000 r-xp 00000000 08:30 4588963 /usr/lib/i386-linux-gnu/libX11-xcb.so.1.0.0 6dad0000-6dad1000 r-xp 00000000 08:30 4588963 /usr/lib/i386-linux-gnu/libX11-xcb.so.1.0.0 6dad1000-6dad2000 rwxp 00001000 08:30 4588963 /usr/lib/i386-linux-gnu/libX11-xcb.so.1.0.0 6dad2000-6dad4000 r-xp 00000000 08:30 4590016 /usr/lib/i386-linux-gnu/libXdamage.so.1.1.0 6dad4000-6dad5000 r-xp 00001000 08:30 4590016 /usr/lib/i386-linux-gnu/libXdamage.so.1.1.0 6dad5000-6dad6000 rwxp 00002000 08:30 4590016 /usr/lib/i386-linux-gnu/libXdamage.so.1.1.0 6dad6000-6daf7000 r-xp 00000000 08:30 3671117 /home/rd/SW.nobackup/SweetHome3D-5.0/lib/libj3dcore-ogl.so 6daf7000-6daf8000 rwxp 00021000 08:30 3671117 /home/rd/SW.nobackup/SweetHome3D-5.0/lib/libj3dcore-ogl.so 6daf8000-6db00000 r-xs 00115000 08:30 3670602 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/resources.jar 6db00000-6dc00000 rwxp 00000000 00:00 0 6dc00000-6dd00000 rwxp 00000000 00:00 0 6dd00000-6ddf5000 rwxp 00000000 00:00 0 6ddf5000-6de00000 ---p 00000000 00:00 0 6de00000-6de02000 r-xs 00000000 08:30 4067794 /var/cache/fontconfig/16326683038b281783a0ef8c680e3a10-le32d4.cache-4 6de02000-6de0c000 r-xp 00000000 08:30 4588426 /usr/lib/i386-linux-gnu/libXrender.so.1.3.0 6de0c000-6de0d000 r-xp 00009000 08:30 4588426 /usr/lib/i386-linux-gnu/libXrender.so.1.3.0 6de0d000-6de0e000 rwxp 0000a000 08:30 4588426 /usr/lib/i386-linux-gnu/libXrender.so.1.3.0 6de0e000-6de18000 r-xp 00000000 08:30 4588104 /usr/lib/i386-linux-gnu/libXcursor.so.1.0.2 6de18000-6de19000 r-xp 00009000 08:30 4588104 /usr/lib/i386-linux-gnu/libXcursor.so.1.0.2 6de19000-6de1a000 rwxp 0000a000 08:30 4588104 /usr/lib/i386-linux-gnu/libXcursor.so.1.0.2 6de1a000-6deaf000 r-xp 00000000 08:30 3670515 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libfontmanager.so 6deaf000-6debc000 rwxp 00094000 08:30 3670515 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libfontmanager.so 6debc000-6dec0000 rwxp 00000000 00:00 0 6dec0000-6dec3000 ---p 00000000 00:00 0 6dec3000-6df11000 rwxp 00000000 00:00 0 [stack:21470] 6df11000-6df16000 r-xp 00000000 08:30 4593504 /usr/lib/i386-linux-gnu/libXdmcp.so.6.0.0 6df16000-6df17000 rwxp 00004000 08:30 4593504 /usr/lib/i386-linux-gnu/libXdmcp.so.6.0.0 6df17000-6df19000 r-xp 00000000 08:30 4588385 /usr/lib/i386-linux-gnu/libXau.so.6.0.0 6df19000-6df1a000 r-xp 00001000 08:30 4588385 /usr/lib/i386-linux-gnu/libXau.so.6.0.0 6df1a000-6df1b000 rwxp 00002000 08:30 4588385 /usr/lib/i386-linux-gnu/libXau.so.6.0.0 6df1b000-6df3f000 r-xp 00000000 08:30 4587890 /usr/lib/i386-linux-gnu/libxcb.so.1.1.0 6df3f000-6df40000 r-xp 00023000 08:30 4587890 /usr/lib/i386-linux-gnu/libxcb.so.1.1.0 6df40000-6df41000 rwxp 00024000 08:30 4587890 /usr/lib/i386-linux-gnu/libxcb.so.1.1.0 6df41000-6df52000 r-xp 00000000 08:30 4591275 /usr/lib/i386-linux-gnu/libXi.so.6.1.0 6df52000-6df53000 r-xp 00010000 08:30 4591275 /usr/lib/i386-linux-gnu/libXi.so.6.1.0 6df53000-6df54000 rwxp 00011000 08:30 4591275 /usr/lib/i386-linux-gnu/libXi.so.6.1.0 6df54000-6df5a000 r-xp 00000000 08:30 4593233 /usr/lib/i386-linux-gnu/libXtst.so.6.1.0 6df5a000-6df5b000 r-xp 00005000 08:30 4593233 /usr/lib/i386-linux-gnu/libXtst.so.6.1.0 6df5b000-6df5c000 rwxp 00006000 08:30 4593233 /usr/lib/i386-linux-gnu/libXtst.so.6.1.0 6df5c000-6e0a9000 r-xp 00000000 08:30 4587563 /usr/lib/i386-linux-gnu/libX11.so.6.3.0 6e0a9000-6e0ab000 r-xp 0014d000 08:30 4587563 /usr/lib/i386-linux-gnu/libX11.so.6.3.0 6e0ab000-6e0ae000 rwxp 0014f000 08:30 4587563 /usr/lib/i386-linux-gnu/libX11.so.6.3.0 6e0ae000-6e0c1000 r-xp 00000000 08:30 4592839 /usr/lib/i386-linux-gnu/libXext.so.6.4.0 6e0c1000-6e0c2000 r-xp 00012000 08:30 4592839 /usr/lib/i386-linux-gnu/libXext.so.6.4.0 6e0c2000-6e0c3000 rwxp 00013000 08:30 4592839 /usr/lib/i386-linux-gnu/libXext.so.6.4.0 6e0c3000-6e106000 r-xp 00000000 08:30 3670552 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/xawt/libmawt.so 6e106000-6e108000 rwxp 00043000 08:30 3670552 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/xawt/libmawt.so 6e108000-6e109000 rwxp 00000000 00:00 0 6e109000-6e18e000 r-xp 00000000 08:30 3670510 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libawt.so 6e18e000-6e195000 rwxp 00085000 08:30 3670510 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libawt.so 6e195000-6e1b9000 rwxp 00000000 00:00 0 6e1b9000-6e228000 r-xp 00000000 08:30 4981221 /lib/i386-linux-gnu/libpcre.so.3.13.1 6e228000-6e229000 r-xp 0006f000 08:30 4981221 /lib/i386-linux-gnu/libpcre.so.3.13.1 6e229000-6e22a000 rwxp 00070000 08:30 4981221 /lib/i386-linux-gnu/libpcre.so.3.13.1 6e22a000-6e230000 r-xp 00000000 08:30 4589138 /usr/lib/i386-linux-gnu/libffi.so.6.0.2 6e230000-6e231000 r-xp 00005000 08:30 4589138 /usr/lib/i386-linux-gnu/libffi.so.6.0.2 6e231000-6e232000 rwxp 00006000 08:30 4589138 /usr/lib/i386-linux-gnu/libffi.so.6.0.2 6e232000-6e245000 r-xp 00000000 08:30 4982956 /lib/i386-linux-gnu/i686/cmov/libresolv-2.19.so 6e245000-6e246000 r-xp 00012000 08:30 4982956 /lib/i386-linux-gnu/i686/cmov/libresolv-2.19.so 6e246000-6e247000 rwxp 00013000 08:30 4982956 /lib/i386-linux-gnu/i686/cmov/libresolv-2.19.so 6e247000-6e249000 rwxp 00000000 00:00 0 6e249000-6e26e000 r-xp 00000000 08:30 4981493 /lib/i386-linux-gnu/libselinux.so.1 6e26e000-6e26f000 r-xp 00024000 08:30 4981493 /lib/i386-linux-gnu/libselinux.so.1 6e26f000-6e270000 rwxp 00025000 08:30 4981493 /lib/i386-linux-gnu/libselinux.so.1 6e270000-6e271000 rwxp 00000000 00:00 0 6e271000-6e28b000 r-xp 00000000 08:30 4981845 /lib/i386-linux-gnu/libz.so.1.2.8 6e28b000-6e28d000 r-xp 00019000 08:30 4981845 /lib/i386-linux-gnu/libz.so.1.2.8 6e28d000-6e28e000 rwxp 0001b000 08:30 4981845 /lib/i386-linux-gnu/libz.so.1.2.8 6e28e000-6e3b4000 r-xp 00000000 08:30 4981375 /lib/i386-linux-gnu/libglib-2.0.so.0.4200.1 6e3b4000-6e3b5000 r-xp 00125000 08:30 4981375 /lib/i386-linux-gnu/libglib-2.0.so.0.4200.1 6e3b5000-6e3b6000 rwxp 00126000 08:30 4981375 /lib/i386-linux-gnu/libglib-2.0.so.0.4200.1 6e3b6000-6e412000 r-xp 00000000 08:30 4587663 /usr/lib/i386-linux-gnu/libgobject-2.0.so.0.4200.1 6e412000-6e413000 r-xp 0005b000 08:30 4587663 /usr/lib/i386-linux-gnu/libgobject-2.0.so.0.4200.1 6e413000-6e414000 rwxp 0005c000 08:30 4587663 /usr/lib/i386-linux-gnu/libgobject-2.0.so.0.4200.1 6e414000-6e468000 r-xp 00000000 08:30 4981871 /lib/i386-linux-gnu/libdbus-1.so.3.8.12 6e468000-6e46a000 r-xp 00053000 08:30 4981871 /lib/i386-linux-gnu/libdbus-1.so.3.8.12 6e46a000-6e46b000 rwxp 00055000 08:30 4981871 /lib/i386-linux-gnu/libdbus-1.so.3.8.12 6e46b000-6e490000 r-xp 00000000 08:30 4590672 /usr/lib/i386-linux-gnu/libdbus-glib-1.so.2.2.2 6e490000-6e491000 r-xp 00024000 08:30 4590672 /usr/lib/i386-linux-gnu/libdbus-glib-1.so.2.2.2 6e491000-6e492000 rwxp 00025000 08:30 4590672 /usr/lib/i386-linux-gnu/libdbus-glib-1.so.2.2.2 6e492000-6e495000 r-xp 00000000 08:30 4597046 /usr/lib/i386-linux-gnu/libgmodule-2.0.so.0.4200.1 6e495000-6e496000 r-xp 00002000 08:30 4597046 /usr/lib/i386-linux-gnu/libgmodule-2.0.so.0.4200.1 6e496000-6e497000 rwxp 00003000 08:30 4597046 /usr/lib/i386-linux-gnu/libgmodule-2.0.so.0.4200.1 6e497000-6e648000 r-xp 00000000 08:30 4602108 /usr/lib/i386-linux-gnu/libgio-2.0.so.0.4200.1 6e648000-6e64b000 r-xp 001b0000 08:30 4602108 /usr/lib/i386-linux-gnu/libgio-2.0.so.0.4200.1 6e64b000-6e64c000 rwxp 001b3000 08:30 4602108 /usr/lib/i386-linux-gnu/libgio-2.0.so.0.4200.1 6e64c000-6e64d000 rwxp 00000000 00:00 0 6e64d000-6e681000 r-xp 00000000 08:30 4588058 /usr/lib/i386-linux-gnu/libgconf-2.so.4.1.5 6e681000-6e682000 r-xp 00033000 08:30 4588058 /usr/lib/i386-linux-gnu/libgconf-2.so.4.1.5 6e682000-6e683000 rwxp 00034000 08:30 4588058 /usr/lib/i386-linux-gnu/libgconf-2.so.4.1.5 6e683000-6e684000 r-xp 00000000 08:30 3670528 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libjawt.so 6e684000-6e685000 rwxp 00000000 08:30 3670528 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libjawt.so 6e685000-6e6b3000 r-xp 00000000 08:30 3670530 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libjpeg.so 6e6b3000-6e6b4000 rwxp 0002e000 08:30 3670530 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libjpeg.so 6e6b4000-6e875000 rwxp 00000000 00:00 0 6e875000-6e889000 r-xp 00000000 08:30 3670538 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libnet.so 6e889000-6e88a000 rwxp 00013000 08:30 3670538 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libnet.so 6e88a000-6e88d000 ---p 00000000 00:00 0 6e88d000-6e8db000 rwxp 00000000 00:00 0 [stack:21469] 6e8db000-6e8e4000 r-xs 000c1000 08:30 3670568 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/javaws.jar 6e8e4000-6e8f2000 r-xs 00193000 08:30 3671114 /home/rd/SW.nobackup/SweetHome3D-5.0/lib/j3dutils.jar 6e8f2000-6e900000 r-xs 000e1000 08:30 3671115 /home/rd/SW.nobackup/SweetHome3D-5.0/lib/jmf.jar 6e900000-6ea00000 rwxp 00000000 00:00 0 6ea00000-6ea01000 r-xp 00000000 08:30 4602094 /usr/lib/i386-linux-gnu/libgthread-2.0.so.0.4200.1 6ea01000-6ea02000 r-xp 00000000 08:30 4602094 /usr/lib/i386-linux-gnu/libgthread-2.0.so.0.4200.1 6ea02000-6ea03000 rwxp 00001000 08:30 4602094 /usr/lib/i386-linux-gnu/libgthread-2.0.so.0.4200.1 6ea03000-6ea05000 r-xs 0004c000 08:30 3671119 /home/rd/SW.nobackup/SweetHome3D-5.0/lib/vecmath.jar 6ea05000-6ea1f000 r-xs 006ae000 08:30 3671107 /home/rd/SW.nobackup/SweetHome3D-5.0/lib/Help.jar 6ea1f000-6ea20000 ---p 00000000 00:00 0 6ea20000-6eaa0000 rwxp 00000000 00:00 0 [stack:21468] 6eaa0000-6eaa3000 ---p 00000000 00:00 0 6eaa3000-6eaf1000 rwxp 00000000 00:00 0 [stack:21467] 6eaf1000-6eaf4000 ---p 00000000 00:00 0 6eaf4000-6eb72000 rwxp 00000000 00:00 0 [stack:21466] 6eb72000-6eb75000 ---p 00000000 00:00 0 6eb75000-6ebf3000 rwxp 00000000 00:00 0 [stack:21465] 6ebf3000-6ebf6000 ---p 00000000 00:00 0 6ebf6000-6ec44000 rwxp 00000000 00:00 0 [stack:21464] 6ec44000-6ec47000 ---p 00000000 00:00 0 6ec47000-6ec95000 rwxp 00000000 00:00 0 [stack:21463] 6ec95000-6ec98000 ---p 00000000 00:00 0 6ec98000-6ece6000 rwxp 00000000 00:00 0 [stack:21462] 6ece6000-6ece7000 ---p 00000000 00:00 0 6ece7000-6ed67000 rwxp 00000000 00:00 0 [stack:21461] 6ed67000-6ef00000 r-xs 02b64000 08:30 3670603 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/rt.jar 6ef00000-6effa000 rwxp 00000000 00:00 0 6effa000-6f000000 ---p 00000000 00:00 0 6f001000-6f00d000 r-xs 002c7000 08:30 3671113 /home/rd/SW.nobackup/SweetHome3D-5.0/lib/j3dcore.jar 6f00d000-6f013000 r-xs 0004f000 08:30 3671118 /home/rd/SW.nobackup/SweetHome3D-5.0/lib/sunflow-0.07.3i.jar 6f013000-6f04b000 r-xs 002ae000 08:30 3671108 /home/rd/SW.nobackup/SweetHome3D-5.0/lib/SweetHome3D.jar 6f04b000-6f07f000 rwxp 00000000 00:00 0 6f07f000-6f080000 ---p 00000000 00:00 0 6f080000-6f100000 rwxp 00000000 00:00 0 [stack:21460] 6f100000-6f1ff000 rwxp 00000000 00:00 0 6f1ff000-6f200000 ---p 00000000 00:00 0 6f200000-6f201000 r-xs 00000000 08:30 4105739 /var/cache/fontconfig/9451a55048e8dbe8633e64d34165fdf2-le32d4.cache-4 6f201000-6f208000 r-xs 0006d000 08:30 3671111 /home/rd/SW.nobackup/SweetHome3D-5.0/lib/freehep-vectorgraphics-svg-2.1.1b.jar 6f208000-6f209000 ---p 00000000 00:00 0 6f209000-6f29b000 rwxp 00000000 00:00 0 [stack:21459] 6f29b000-6f2a9000 rwxp 00000000 00:00 0 6f2a9000-6f2bf000 rwxp 00000000 00:00 0 6f2bf000-6f3ff000 rwxp 00000000 00:00 0 6f3ff000-6f411000 rwxp 00000000 00:00 0 6f411000-6f41f000 rwxp 00000000 00:00 0 6f41f000-6f435000 rwxp 00000000 00:00 0 6f435000-6f574000 rwxp 00000000 00:00 0 6f574000-6f587000 rwxp 00000000 00:00 0 6f587000-6f61f000 rwxp 00000000 00:00 0 6f61f000-71a20000 rwxp 00000000 00:00 0 71a20000-73620000 rwxp 00000000 00:00 0 73620000-76040000 rwxp 00000000 00:00 0 76040000-9e0d0000 rwxp 00000000 00:00 0 9e0d0000-a05b0000 rwxp 00000000 00:00 0 a05b0000-b3620000 rwxp 00000000 00:00 0 b3620000-b3621000 r-xs 00000000 08:30 4067305 /var/cache/fontconfig/4794a0821666d79190d59a36cb4f44b5-le32d4.cache-4 b3621000-b3623000 r-xs 00008000 08:30 3671110 /home/rd/SW.nobackup/SweetHome3D-5.0/lib/batik-svgpathparser-1.7.jar b3623000-b362f000 r-xs 00108000 08:30 3671112 /home/rd/SW.nobackup/SweetHome3D-5.0/lib/iText-2.1.7.jar b362f000-b3638000 rwxp 00000000 00:00 0 b3638000-b36ef000 rwxp 00000000 00:00 0 b36ef000-b392f000 rwxp 00000000 00:00 0 b392f000-b66ef000 rwxp 00000000 00:00 0 b66ef000-b66fe000 r-xp 00000000 08:30 3670546 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libzip.so b66fe000-b6700000 rwxp 0000e000 08:30 3670546 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libzip.so b6700000-b67ff000 rwxp 00000000 00:00 0 b67ff000-b6800000 ---p 00000000 00:00 0 b6800000-b6801000 r-xs 00000000 08:30 4072593 /var/cache/fontconfig/3fe29f0c9fa221c8ee16555d4835b3ab-le32d4.cache-4 b6801000-b6803000 r-xs 00077000 08:30 3671109 /home/rd/SW.nobackup/SweetHome3D-5.0/lib/Textures.jar b6803000-b680a000 r-xs 00349000 08:30 3671106 /home/rd/SW.nobackup/SweetHome3D-5.0/lib/Furniture.jar b680a000-b6812000 rwxs 00000000 00:21 2191038 /tmp/hsperfdata_rd/21455 b6812000-b681d000 r-xp 00000000 08:30 4982923 /lib/i386-linux-gnu/i686/cmov/libnss_files-2.19.so b681d000-b681e000 r-xp 0000a000 08:30 4982923 /lib/i386-linux-gnu/i686/cmov/libnss_files-2.19.so b681e000-b681f000 rwxp 0000b000 08:30 4982923 /lib/i386-linux-gnu/i686/cmov/libnss_files-2.19.so b681f000-b6829000 r-xp 00000000 08:30 4982927 /lib/i386-linux-gnu/i686/cmov/libnss_nis-2.19.so b6829000-b682a000 r-xp 00009000 08:30 4982927 /lib/i386-linux-gnu/i686/cmov/libnss_nis-2.19.so b682a000-b682b000 rwxp 0000a000 08:30 4982927 /lib/i386-linux-gnu/i686/cmov/libnss_nis-2.19.so b682b000-b684f000 r-xp 00000000 08:30 3670523 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libjava.so b684f000-b6851000 rwxp 00023000 08:30 3670523 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libjava.so b6851000-b6858000 r-xp 00000000 08:30 4982959 /lib/i386-linux-gnu/i686/cmov/librt-2.19.so b6858000-b6859000 r-xp 00006000 08:30 4982959 /lib/i386-linux-gnu/i686/cmov/librt-2.19.so b6859000-b685a000 rwxp 00007000 08:30 4982959 /lib/i386-linux-gnu/i686/cmov/librt-2.19.so b685a000-b685d000 ---p 00000000 00:00 0 b685d000-b68ab000 rwxp 00000000 00:00 0 [stack:21458] b68ab000-b68ef000 r-xp 00000000 08:30 4982913 /lib/i386-linux-gnu/i686/cmov/libm-2.19.so b68ef000-b68f0000 r-xp 00043000 08:30 4982913 /lib/i386-linux-gnu/i686/cmov/libm-2.19.so b68f0000-b68f1000 rwxp 00044000 08:30 4982913 /lib/i386-linux-gnu/i686/cmov/libm-2.19.so b68f1000-b70a6000 r-xp 00000000 08:30 3670551 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/server/libjvm.so b70a6000-b70fa000 rwxp 007b5000 08:30 3670551 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/server/libjvm.so b70fa000-b7519000 rwxp 00000000 00:00 0 b7519000-b76bd000 r-xp 00000000 08:30 4982909 /lib/i386-linux-gnu/i686/cmov/libc-2.19.so b76bd000-b76bf000 r-xp 001a4000 08:30 4982909 /lib/i386-linux-gnu/i686/cmov/libc-2.19.so b76bf000-b76c0000 rwxp 001a6000 08:30 4982909 /lib/i386-linux-gnu/i686/cmov/libc-2.19.so b76c0000-b76c3000 rwxp 00000000 00:00 0 b76c3000-b76c6000 r-xp 00000000 08:30 4982912 /lib/i386-linux-gnu/i686/cmov/libdl-2.19.so b76c6000-b76c7000 r-xp 00002000 08:30 4982912 /lib/i386-linux-gnu/i686/cmov/libdl-2.19.so b76c7000-b76c8000 rwxp 00003000 08:30 4982912 /lib/i386-linux-gnu/i686/cmov/libdl-2.19.so b76c8000-b76cf000 r-xp 00000000 08:30 3670507 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/jli/libjli.so b76cf000-b76d1000 rwxp 00006000 08:30 3670507 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/jli/libjli.so b76d1000-b76e9000 r-xp 00000000 08:30 4982036 /lib/i386-linux-gnu/i686/cmov/libpthread-2.19.so b76e9000-b76ea000 r-xp 00017000 08:30 4982036 /lib/i386-linux-gnu/i686/cmov/libpthread-2.19.so b76ea000-b76eb000 rwxp 00018000 08:30 4982036 /lib/i386-linux-gnu/i686/cmov/libpthread-2.19.so b76eb000-b76ee000 rwxp 00000000 00:00 0 b76ee000-b76ef000 r-xs 00000000 08:30 4067762 /var/cache/fontconfig/e0aa53bcfa504e64f87823c16bc01eb6-le32d4.cache-4 b76ef000-b76f6000 r-xp 00000000 08:30 4982919 /lib/i386-linux-gnu/i686/cmov/libnss_compat-2.19.so b76f6000-b76f7000 r-xp 00006000 08:30 4982919 /lib/i386-linux-gnu/i686/cmov/libnss_compat-2.19.so b76f7000-b76f8000 rwxp 00007000 08:30 4982919 /lib/i386-linux-gnu/i686/cmov/libnss_compat-2.19.so b76f8000-b76f9000 rwxp 00000000 00:00 0 b76f9000-b76fa000 r-xp 00000000 00:00 0 b76fa000-b770f000 r-xp 00000000 08:30 4982918 /lib/i386-linux-gnu/i686/cmov/libnsl-2.19.so b770f000-b7710000 r-xp 00015000 08:30 4982918 /lib/i386-linux-gnu/i686/cmov/libnsl-2.19.so b7710000-b7711000 rwxp 00016000 08:30 4982918 /lib/i386-linux-gnu/i686/cmov/libnsl-2.19.so b7711000-b7713000 rwxp 00000000 00:00 0 b7713000-b771e000 r-xp 00000000 08:30 3670545 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libverify.so b771e000-b771f000 rwxp 0000b000 08:30 3670545 /home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/libverify.so b771f000-b7721000 rwxp 00000000 00:00 0 b7721000-b7722000 r-xp 00000000 00:00 0 [vdso] b7722000-b7724000 r--p 00000000 00:00 0 [vvar] b7724000-b7743000 r-xp 00000000 08:30 4980830 /lib/i386-linux-gnu/ld-2.19.so b7743000-b7744000 r-xp 0001f000 08:30 4980830 /lib/i386-linux-gnu/ld-2.19.so b7744000-b7745000 rwxp 00020000 08:30 4980830 /lib/i386-linux-gnu/ld-2.19.so bfe3f000-bfe60000 rwxp 00000000 00:00 0 [stack] VM Arguments: jvm_args: -Xmx1024m -Djava.library.path=./lib -Dcom.eteks.sweethome3d.applicationId=SweetHome3D#Installer java_command: com.eteks.sweethome3d.SweetHome3D -open Launcher Type: SUN_STANDARD Environment Variables: PATH=/home/rd/perl5/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games LD_LIBRARY_PATH=/home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386/server:/home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/lib/i386:/home/rd/SW.nobackup/SweetHome3D-5.0/jre1.6.0_45/../lib/i386 SHELL=/bin/bash DISPLAY=:0 Signal Handlers: SIGSEGV: [libjvm.so+0x7285f0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGBUS: [libjvm.so+0x7285f0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGFPE: [libjvm.so+0x5e21c0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGPIPE: [libjvm.so+0x5e21c0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGXFSZ: [libjvm.so+0x5e21c0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGILL: [libjvm.so+0x5e21c0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000 SIGUSR2: [libjvm.so+0x5e5420], sa_mask[0]=0x00000000, sa_flags=0x10000004 SIGHUP: [libjvm.so+0x5e5000], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGINT: [libjvm.so+0x5e5000], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGTERM: [libjvm.so+0x5e5000], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGQUIT: [libjvm.so+0x5e5000], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 --------------- S Y S T E M --------------- OS:8.1 uname:Linux 3.16.0-4-686-pae #1 SMP Debian 3.16.7-ckt11-1 (2015-05-24) i686 libc:glibc 2.19 NPTL 2.19 rlimit: STACK 8192k, CORE 0k, NPROC 32201, NOFILE 65536, AS infinity load average:0.31 0.63 0.77 /proc/meminfo: MemTotal: 4138016 kB MemFree: 214232 kB MemAvailable: 663480 kB Buffers: 44504 kB Cached: 602688 kB SwapCached: 235464 kB Active: 2029956 kB Inactive: 870256 kB Active(anon): 1739508 kB Inactive(anon): 612080 kB Active(file): 290448 kB Inactive(file): 258176 kB Unevictable: 80 kB Mlocked: 80 kB HighTotal: 3278344 kB HighFree: 50940 kB LowTotal: 859672 kB LowFree: 163292 kB SwapTotal: 8047636 kB SwapFree: 6236912 kB Dirty: 4 kB Writeback: 0 kB AnonPages: 2207884 kB Mapped: 251856 kB Shmem: 98300 kB Slab: 227840 kB SReclaimable: 180064 kB SUnreclaim: 47776 kB KernelStack: 9800 kB PageTables: 56200 kB NFS_Unstable: 0 kB Bounce: 44 kB WritebackTmp: 0 kB CommitLimit: 10116644 kB Committed_AS: 14102984 kB VmallocTotal: 122880 kB VmallocUsed: 33640 kB VmallocChunk: 72868 kB HardwareCorrupted: 0 kB AnonHugePages: 0 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 2048 kB DirectMap4k: 59384 kB DirectMap2M: 847872 kB CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 11, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3 /proc/cpuinfo: processor : 0 vendor_id : GenuineIntel cpu family : 6 model : 15 model name : Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz stepping : 11 microcode : 0xb6 cpu MHz : 2664.000 cache size : 4096 KB physical id : 0 siblings : 2 core id : 0 cpu cores : 2 apicid : 0 initial apicid : 0 fdiv_bug : no f00f_bug : no coma_bug : no fpu : yes fpu_exception : yes cpuid level : 10 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe nx lm constant_tsc arch_perfmon pebs bts aperfmperf pni dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm lahf_lm dtherm tpr_shadow vnmi flexpriority bogomips : 5343.58 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual power management: processor : 1 vendor_id : GenuineIntel cpu family : 6 model : 15 model name : Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz stepping : 11 microcode : 0xb6 cpu MHz : 2664.000 cache size : 4096 KB physical id : 0 siblings : 2 core id : 1 cpu cores : 2 apicid : 1 initial apicid : 1 fdiv_bug : no f00f_bug : no coma_bug : no fpu : yes fpu_exception : yes cpuid level : 10 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe nx lm constant_tsc arch_perfmon pebs bts aperfmperf pni dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm lahf_lm dtherm tpr_shadow vnmi flexpriority bogomips : 5343.58 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual power management: Memory: 4k page, physical 4138016k(214232k free), swap 8047636k(6236912k free) vm_info: Java HotSpot(TM) Server VM (20.45-b01) for linux-x86 JRE (1.6.0_45-b06), built on Mar 26 2013 13:50:03 by "java_re" with gcc 3.2.1-7a (J2SE release) time: Tue Jul 28 22:19:12 2015 elapsed time: 3 seconds rd@blackbox:~/SW.nobackup/SweetHome3D-5.0$
[Jul 28, 2015, 9:24:10 PM]
[Link]
AraiBob
Re: sweethome3D crashes during startup
Sir, I have never had an abort. Either it will start, and continue to run, or it won't start. Ubuntu Linux 14.4 LTS upgraded, and SH3d to latest version, also. It is possible the driver used for your video card is the culprit. See if you can upgrade. In my case, the initial installation used the 'default' video driver, and it was very slow. I then used the 'approved' vendor driver and it worked great! The last time I did a full install of Ubuntu, a few months ago, the default video driver worked just fine.
[Nov 21, 2015, 5:56:28 AM]
[Link]
