Other rendering quality levels
This topic has been viewed 132512 times and has 41 replies
Thread status: Active
Questions about extending features and developing plug-ins [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
enkonyito
Post by enkonyito »
To customize the photo rendering properties, I modify them in a text editor then I save the SweetHome3D.l4j.ini file in the installation folder and at last I relaunch the program.
As it is a bit tedious over time, is it possible to take into account these other rendering quality levels by compiling the source files or adding advanced settings in the photo panel using a plug-in?
I think it might interest some users.
EnkoNyito
User avatar
Country: Paris, France
Contact:
Re: Other rendering quality levels
Post by Puybaret »
If you want, you can change the values in the source code, and run the program with Eclipse. All the photo rendering properties are used in PhotoRenderer class (search calls to getRenderingParameterValue method).
You could also create a plug-in that would set the rendering properties with calls to System.setProperty method.
enkonyito
Post by enkonyito »
Thanks for your answer!
The option of the source code with Eclipse is useful mostly for testing and helps make other changes to the program.
I would keep the slider 4 position for predefined qualities:
  - Q1 : overview of 3D view with shading
  - Q2 (low) : globalIllumination = default, diffusedBounces = 1
  - Q3 (medium) : diffusedBounces = 0
  - Q4 (high) : globalIllumination = path, diffusedBounces >= 1
I will deal with the option of plug-in in depth for usual use.
EnkoNyito
User avatar
Country: Netherlands
Post by hansmex »
Good idea! I've asked for a similar change.
enkonyito
Post by enkonyito »
I based on these configurations and some tests for predefined qualities.
The addition of the medium level was possible by modifying the files associated with the simple photo panel, photos panel at points of view and video panel.
The program works fine with eclipse or a runnable jar.
Quality 0 : 3D view
Image Image
Quality 1 : default global illumination
Image Image
Quality 2 : contrasting global illumination
Image Image
Quality 3 : indirect global illumination
Image Image
Is there a manipulation to do if the jar file not running on another computer?
EnkoNyito
User avatar
Contact:
Post by Puybaret »
The default jarExecutable Ant target generates a Jar executable file able to run under Windows, Mac OS X and Linux, with 32 or 64 bit architecture.
enkonyito
Post by enkonyito »
Emmanuel, my mistake was to do export runnable jar in Eclipse. By using the build.xml of the source and Ant, the created jar works on another system.
Those interested can test these other rendering quality levels with SH3D-5.0_advanced.jar .
With constrasting GI, use an interior light if not the image will be very dark.
With indirect GI, use a sky without texture otherwise the image will be completely black.
Quality 3_without ceiling light
Quality 3_with ceiling light
EnkoNyito
User avatar
Post by hansmex »
Thanks you for your file.
I downloaded it and did a few quick tests.
Q1 - completely distorted image
Q2 - usable image
Q3 - usable image
Q4 - overexposed image
Can you explain what the differences are between the settings and how we can get the best results?
enkonyito
Post by enkonyito »
Hans, I have not done tests on Mac OS X and Linux. I don't know if there can be a difference with Windows.
new Q0 = old Q1 : 3D View
new Q1 = old Q2 : default rendering
new Q2 : rendering without diffused bounces
new Q3 : rendering with diffused bounces
For more details, you can consult PhotoRenderer.properties file I edited in the source code.
Thanks for your feedback.
If you get the same result, can you put images to illustrate it?
EnkoNyito
enkonyito
Post by enkonyito »
Hi all,
You can also test with SH3D-5.0_advanced a ceiling light less powerful and better centered for complex polygonal rooms.
The AdvancedSettings_PhotoRendering plug-in will allow you to modify the photo renderer properties. (parameters definition)
SH3D standard
SH3D advanced
Good use!
EnkoNyito
Post Reply New Topic
Who is online
