Other rendering quality levels
This topic has been viewed 132548 times and has 41 replies
Thread status: Active
Questions about extending features and developing plug-ins [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
User avatar
Country: Netherlands
Re: Other rendering quality levels
Post by hansmex »
This is exciting!! Or it will be when it works.
After downloading the plugin and installing it, SH3D doesn't start anymore. After deleting the plugin, everything is back to normal.
System: Kubuntu 14.04 64-bits (fresh, standard installation).
I hope you can fix this...
enkonyito
Post by enkonyito »
Can you check the java version used by the program?
My SH3D-5.0 uses Java 1.8.
This is perhaps the same problem as last time . [:(]
EnkoNyito
User avatar
Post by hansmex »
Because Java 8 causes problems under Ubuntu, I always use Java 6.
That is also the version that comes (for the same reason) with the installer version of SH3D.
enkonyito
Post by enkonyito »
By testing with SH3D-4.6, the problem occurred.
Version 1.1 of the plug-in is compatible with Java 6.
EnkoNyito
User avatar
Country: Paris, France
Contact:
Post by Puybaret »
Thanks, it works this time [:)]
Not with Java Web Start version, but you can't do anything against that because it's due to security reasons in that environment.
User avatar
Vkbear0
Post by Vkbear0 »
Thank you for this reply! This helps me a lot!
-The Hobbyist
Post by okh »
Interesting plug-in and like the concept. While most of the menu items are understandable, some are not obvious (causticsPhotons???).
Photo (and video) rendering is always a trade-off between time and quality, and I wonder how the different values influence on performance. Trying and failing takes a bit too long. Maybe a little introduction/description/guide could be useful? Or just a little more explanatory text in the menu?
enkonyito
Post by enkonyito »
The plug-in in its current state is made for users who used a SweetHome3D.l4j.ini file, a Linux launch script or Jar command lines to change the photo renderer properties.
In this thread , Emmanuel Puybaret gives some explanation about those properties.
And you can find information on caustics here .
Here are the definitions of the quality parameters given in the PhotoRenderer.properties file:
* Minimum and maximum antialiasing used to compute image
* Global illumination algorithm: "default" or "path"
- "default" uses ambient occlusion during day hours in virtual visit mode
- "path" takes much longer to compute but gives more realistic view at day hours
* Maximum bounces done by light rays when global illumination "path" is used
- Increasing this value greatly slows down rendering process
* Caustics photons count, with 0 producing no caustics
- If different from 0, should be higher than 1000000 to obtain some visible effect
* Shader used to render shiny materials: "default", "glossy" or "silk"
- "default" uses silk shader at high quality level and in virtual view mode, glossy otherwise
* Focus distance in cm when depth of field is used
* Lens radius when depth of field is used
- A bigger value produces a narrower depth of field
EnkoNyito
Post by okh »
Thanks, now I am confused at a higher level. [:)] Looking forward to trying. ok
enkonyito
Post by enkonyito »
Version 1.2 of the plug-in incorporates some additional information.
EnkoNyito
Post Reply New Topic
Who is online
