Other rendering quality levels
This topic has been viewed 132940 times and has 41 replies
Thread status: Active
Questions about extending features and developing plug-ins [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
User avatar
svedel77
Country: +45 Denmark
Re: Other rendering quality levels (Advanced settings of photo rendering plug-in)
Post by svedel77 »
I think this is a great idea for a plugin. If you could make the possibilities for rendering movies at 60 FPS I would be very greatful.
User avatar
harbinger
Country: Clearwater, FL, US
Post by harbinger »
Thanks - i was able to view the PhotoRenderer properties file and that answered the questions well enough. I was able to come up with better renders thanks to the explanations.
I will also take a look at the PDF you pointed to...
User avatar
Wolf1066
Country: New Zealand
Post by Wolf1066 »
At the risk of a major "thread necro", I've got to say: what an awesome plugin! Just found it and installed it this evening and had a bit of a play - primarily to get access to the global illumination options - and I'm absolutely rapt!
Many thanks enkonyito.
Crazy Kiwi bloke
Debian "buster" 10 64bit
Sweet Home 3D 6.3 64bit
i5 Quad-core 3.1GHz
8GB 1333MHz DDR3 RAM
enkonyito
Re: Advanced settings of photo rendering plug-in
Post by enkonyito »
Version 1.4
- compatible with SH3D-7.0 and higher
EnkoNyito
User avatar
Country: Paris, France
Contact:
Post by Puybaret »
Thanks for adding YafaRay settings [:)]
sjb007
Post by sjb007 »
So just to clarify... I have SH3D 7 (with Yafaray built in) and AdvancedSettingsPhotoRendering 1.4 plugin.
Should we uninstall YafarayRendering plugin completely? Or does it still have some function?
User avatar
Contact:
Post by Puybaret »
I don’t see a good reason to keep YafaRayRendering plug-in installed if you run Sweet Home 3D v7.
It offers less features than YafaRay renderer version in Sweet Home 3D.
enkonyito
Post by enkonyito »
Version 1.4.1
  • removal of properties identical to the default ones
EnkoNyito
CinemaWalls
Post by CinemaWalls »
I have already used these settings, but that's the problem, that even the value "normalLens.radius = 1" already gives such a blur as if there is a lens with a 1.8 "hole" on the camera - the DOF is very small.
At the value of radius = 3, the grip is generally several centimeters, almost everything is out of focus. About the other values, more than 3 - I don't understand at all - why are they?
I would like to suggest making several radius values up to one, instead of those useless ones. This would greatly improve the capabilities and quality of the renderers.
I'm applying the renderers for an example
https://imgur.com/a/wJ2WAyb
https://imgur.com/a/17UqX0A
User avatar
Contact:
Post by Puybaret »
Try a value smaller than 1 (0.5, 0.2 etc)
Post Reply New Topic
Who is online
