Furniture Library editor shows nothing
Hi! Importing a furniture library onto the program doesn't take any effect onto the furniture window. I can see the file is copied to application data\... folder but SH3d doesnt see nothing new, just the default library.
Also, when I try to see an external library, like Contributions.sh3f file using Furniture Editor, it doesnt show nothing too. What can I do? :(
Re: Furniture Library editor shows nothing
Try to launch the following command in a command window:
java -jar C:\FurnitureLibraryEditor-1.17.jar
(to get the right path of FurnitureLibraryEditor-1.17.jar file, just drag and drop its file icon in the command window). When the bug happens, some text reporting an exception should appear in the command window. If you could copy/paste that text, it would be helpful.
