Total posts in this thread: 2
Previous Thread This topic has been viewed 3954 times and has 1 reply Next Thread
doktorinjh
Error: Can't import furniture library
I've tried to install several furniture libraries and I get the same error every time: "Can't import furniture library". I've tried to double click on the SH3F file with the program open and closed, and I've tried to import from the menu, but I get the same error.
The Readme.txt says to look in this folder: C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D\furniture but I don't have that folder installed anywhere. I have some files under c:\Program Files\Sweet Home 3D\jre1.8.0_51\ that look like they could match, but I don't want to start throwing files into the wrong place.
Thanks for any help!
[Sep 17, 2015, 1:56:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Error: Can't import furniture library
I wonder if you have actually the rights to write in your application data folder, or you don't benefit of a large enough roaming space.
Please try to change a setting in the preferences, relaunch the program and check if the setting you set previously is kept. If it wasn't, please try with an other user account.
[Sep 18, 2015, 8:35:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
