Total posts in this thread: 5
Previous Thread This topic has been viewed 3483 times and has 4 replies Next Thread
hseiden
sad How do I swap the door opening (not just rotate the door on the wall/frame?
I want to change the door opening from left handed to right handed, vice versa. How do I do that?
[Oct 12, 2015, 8:50:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
Re: How do I swap the door opening (not just rotate the door on the wall/frame?
See this topic.
http://www.sweethome3d.com/support/forum/viewthread_thread,6090
Hawk
[Edit 1 times, last edit by HawkDawg at Oct 13, 2015, 7:12:32 AM]
[Oct 13, 2015, 7:10:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Make sure plan is unlocked, Modify furniture, check Mirrored shape. Direction of door: move towards one of the wall sides or change angle in Modify furniture. Door openings need SH3D extra properties to be visible (not directly imported OBJ, DAE, KMZ, 3DZ or ZIP files). ok
[Oct 13, 2015, 7:18:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hseiden
biggrin Re: How do I swap the door opening (not just rotate the door on the wall/frame?
Yep. that did it. Thanks! Now, do you know where I can find a template for a bifold door? I have a need for a two section single door for a closet. Also a clear shower door. Any further help appreciated.
Henry
[Oct 13, 2015, 12:14:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
There's a shower door on this page of the SH3D website. Just scroll down a bit. It's in the first category. I don't know if it's clear or not though. I haven't tried that one particular model.
There's also a few links at the bottom of this page of the SH3D website. I've been to all of them but I don't recall seeing a two section single door at any of them, but there is a ton of stuff that might interest you. You'll just have to scope them out.
Hawk
[Edit 1 times, last edit by HawkDawg at Oct 13, 2015, 1:07:08 PM]
[Oct 13, 2015, 1:06:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
