Re: How do I swap the door opening (not just rotate the door on the wall/frame?
Make sure plan is unlocked, Modify furniture, check Mirrored shape. Direction of door: move towards one of the wall sides or change angle in Modify furniture. Door openings need SH3D extra properties to be visible (not directly imported OBJ, DAE, KMZ, 3DZ or ZIP files). ok
Yep. that did it. Thanks! Now, do you know where I can find a template for a bifold door? I have a need for a two section single door for a closet. Also a clear shower door. Any further help appreciated.
There's a shower door on this page of the SH3D website. Just scroll down a bit. It's in the first category. I don't know if it's clear or not though. I haven't tried that one particular model. There's also a few links at the bottom of this page of the SH3D website. I've been to all of them but I don't recall seeing a two section single door at any of them, but there is a ton of stuff that might interest you. You'll just have to scope them out.
---------------------------------------- Hawk
[Edit 1 times,
last edit by HawkDawg at Oct 13, 2015, 1:07:08 PM]
