Furniture librari editor and texture editor problem
I also have problem related to my sweet home first thread...When i click on jar executables of furniture editor and texture editor located in system drive C, they dont fork and open...when i copy files to partition d or e and f, when i double click they work.
where you'll replace path\to by the real path to the Jar file (you can also drag and drop the FurnitureLibraryEditor-1.18.jar file in the cmd window to get its full path more quickly. In case of error, the cmd window should display some information that will be helpful to understand your issue.
Re: Furniture librari editor and texture editor problem
Same here. I do not have Java installed but I do have the SH3D installer with Java. Here's what I get from the command window.
Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Hawk>"X:\Software2\Graphics\Sweet Home 3D\FurnitureLibraryEditor-1.18.jar"
C:\Documents and Settings\Hawk>java -jar X:\Software2\Graphics\Sweet Home 3D\FurnitureLibraryEditor-1.18.jar 'java' is not recognized as an internal or external command, operable program or batch file.
I Executed jar file through cmd but nothing heppens...just like i click on executable...i see the sand clock and nothing. I also have to say, when i put this hdd (with this partition c and also have partition d )on another computer and i try to execute furniture library editor its the same...but when i execute in any other partition (partition d on same hdd or on another hdd)exept this partition , then jar file works. So jar executables dont work when partition is active with drive letter c, and also when partition is not system when i plug hdd on another pc.
OK! Taking your suggestion, I copied the jar file to D drive and got the same thing.
C:\Documents and Settings\Hawk>java -jar D:\Modeling\Sweet Home 3D\lib\FurnitureLibraryEditor-1.18.jar 'java' is not recognized as an internal or external command, operable program or batch file.
---------------------------------------- Hawk
[Edit 2 times,
last edit by HawkDawg at Oct 26, 2015, 9:37:42 PM]
HawkDawg, you must install Java to run the Furniture Library Editor. l4fr4gol4, I don't know what's going on in your case, but I'm sure that the Editor can be run from any drive.
Ah! I thought you could run it with the Java that comes with the SH3D installer. Thanks for clearing that up for me.
The program is available as a 4.6 MB JAR executable file and requires you installed Java on your machine (or reuse the Java version embedded with Sweet Home 3D installer).
I tried that and it looks like the space after Sweet causes the command window to not accept the address of the installation of SH3D.
C:\Documents and Settings\Hawk>"D:\Modeling\Sweet Home 3D\jre1.8.0_60\bin\javaw.exe"
C:\Documents and Settings\Hawk>D:\Modeling\Sweet Home 3D\jre1.8.0_60\bin\javaw.exe -jar X:\Software2\Graphics\Sweet Home 3D\FurnitureLibraryEditor-1.18.jar 'D:\Modeling\Sweet' is not recognized as an internal or external command, operable program or batch file.
[Edit 1 times,
last edit by HawkDawg at Oct 28, 2015, 3:28:19 PM]
